X Factor feed
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Excellent to hear!
Not getting anything here but 5/6 feeds are always difficult with my dish size.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Excellent to hear!
I hope the rain subsdies at your end. It's gone from 9.5 to 12db for me and hasn't been raining here so maybe pumped it up at their end.
Yes the wick has been turned up, for some reason..
dankargo
Brentwood, UK
90cm Motorised
Brentwood
And with the feed power getting stronger, so does the heavy rain here. Absolutely lashing it down here so I've switched to ITV :(
Any idea if the talkback is also active for the Sunday results? I'll try again tomorrow if it is!
I would imagine it will be the same tomorrow.
Adam792
Cheltenham
I think these probably have something to do with feeding it live to MTV Sub in Finland. They've been simulcasting it live over the past few weeks apparently.
Sent from my iPhone using Tapatalk
dankargo
Brentwood, UK
90cm Motorised
Brentwood
I think you're right there.
Was the 10E feed easily receivable on an 80cm? The 12.5w feed was very strong, 72% on mine.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
10e is back, same freq with talkback etc.
Paul Field
None
USA
What was heard on talkback yesterday when louis tomlinsons set wasnt ready and they jumped back to talking to the judges after playing his intro?
Jamie A
The 12.5°W feed is up and has a second audio track tonight. It's very faint though
Paul Field
None
USA
You can increase the volume on the low tracks using ffmpeg once you get then on the pc
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
They have been setting up the 'Invisi-dot-cue-dot heartbeat' for Cheswick which sounds very technical... :D
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
The chiswick man is very very loud so be careful if you up the volume to hear the whispering.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Thanks for the tip on 12.5w
Coming through at 74%! Annoyingly I can't record as I'm getting 'USB too slow to action' on my openbox. Must be a huge bitrate!
Jamie A
Overall bit rate : 46.5 Mbps. Forgot to mention it's in 4:2:2.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
If anyone is recording, could I be cheeky and ask if it's possible for someone to extract purely the talkback track for me?
My box just won't record it due to the bitrate :(
Yes recording here. Volume on the Control room feed is much more like it tonight
Jamie A
I'm not familiar with the Openbox, but is there not an option to manually set the video PID to 0 so it defaults to recording the audio pids as if it were radio?
