aligning sat dish
satelliteman
Should be 0.7w or 0.007w, how ever it's displayed.
greengekko
technomate TM-6900 HD combo.technomate TM-2600 super diseqc h-h motor.1 metre fracarro dish
uk
just lowered it will send you another pic
greengekko
uk
satellite pic
greengekko
uk
datellite picture
satelliteman
Dish elevation is certainly far too low for reference satellite.
greengekko
uk
longitude?as on motor or reciever
In USALS, on your Receiver.
Please look again at Posts 7, 19, 26, 54, 55, 60, 61 etc where we've given you the correct Longitude to enter.
0.7W
greengekko
uk
ive got it on 20 at the mo (dish)
greengekko
uk
this is what its on at the mo
Right - good one: I can see what's causing the problem now.
Ignore the leading zero as in 07.0 and then you'll see it's actually showing 7W
What you need to do is adjust it so it says 00.70 which is how it will show the correct Longitude of Zero POINT Seven West
ie Make sure the decimal point is immediately BEFORE the 7, not after it.
Ok?
Edit: Then Post up another pic of it so we can prove it's right - then leave it alone!
greengekko
uk
this is what it shows ready to go
sonnetpete
wordpress.com
Normandy, France
As Satman says, the dish face is far too low to receive anything from Thor. And Tivù is correct, it should be 0.7°W
I still think your pole is way off vertical. If your house wall is vertical, the clamps holding the pole to the brackets should be both in the same position. At the moment it looks like your top clamp is nearer the wall than the bottom one. However, concentrate on at least getting a signal. Fine tuning the set up can wait.
I'm off for lunch and to dig out a scart lead from the builders mess in the porch. Hope you have success while I'm away!!
greengekko
uk
this is what happens if i put it in as you said
greengekko
uk
00.7 is that correct?
sonnetpete
wordpress.com
Normandy, France
Noooo. 0.7W NOT, REPEAT NOT, 7°W
sonnetpete
wordpress.com
Normandy, France
Yes, thankfully that looks okay!!
............. d'accord
That is now CORRECT.
Leave it be ................
greengekko
uk
right this is how its been set up can you tell me if this is correct now:)
Yes indeed.
But when you start the final alignment, you need to select Thor, not 28E.
Thor is your South Satellite, so is the optimum one to use (It's not vital, when using USALS, but given your trials and tribulations so far I strongly recommend it!)
So choose "Go To Reference", then select Thor.
Best Transponder on Thor is the one which carries BBC World
ie 11325 H 24500 7/8
The Motor will move only a tiny amount from the due South position as the Longitude of Thor is almost identical to your own.
So hopefully all you will need to do is alter the dish bracket angle to find a signal.
Mickha
North West
Send the dish to Thor then please upload some new pictures as your dish looks incorrect if on 28E.
