aligning sat dish
greengekko
technomate TM-6900 HD combo.technomate TM-2600 super diseqc h-h motor.1 metre fracarro dish
uk
ive done go to reference and selected thor and transponders on 11.325(h) 24500 what do i do now?
greengekko
uk
latest pic
Well you need to align the dish/motor assembly.
As said, the later pics of your dish show it being too low, so set it back to 22.5 as a starting point.
Then, you need to trim the azimuth (direction) of the system by moving the entire motor/dish assembly around the mounting pole and you need to trim the dish elevation by making small adjustment to the dish bracket.
But if you've got everything else apart from the initial dish bracket angle more or less ok, it's likely that you'll start to get a signal by altering the dish bracket alone.
Once you've found the Satellite, then you need make only very small adjustments to get optimum Strength and Quality.
I suggest that you stop for now and consult all the guides previously linked so you are clear in your own mind what you are about to do.
greengekko
uk
just elevated the dish up and ive got 80% blue (quality) what now
Cripes, that was quick.
Scan that Transponder and make sure BBC World comes up.
If it does, you've proved you are on the correct Satellite and need only make further very small adjustments as stated in my previous Post.
Edit: This Thread is playing havoc with my forlorn attempts to trim the hedges!
greengekko
uk
Thankyou to you all for helping me and your patience.will let you know how i get on :)
Please do.
We are a self-help Forum, so now you've got the hang of it (It seems) the rest is up to you. ie Optimising alignment, learning how to use your Receiver, checking all other Satellites of interest, etc.
But of course if you get really stuck, someone will be around to advise.
greengekko
uk
im getting telenor test is that from thor lol
Not got time to check, but you can check received Channels against published lists on various sites such as _flysat.com, _lyngsat.com and _kingofsat.net
Have a look at one of them and you'll be able to work out what Satellite you've actually got and then adjust the dish accordingly.
The fact that you are getting anything at all is a major success .................................. :)
greengekko
uk
when you say bbc do you mean radio lol
No ........... BBC World News
I refer you to the listings sites linked in my last Post.
Edit: Telenor are associated with Thor, so I suggest to prove things you carry out an Auto Scan (or Blind Scan) to see what else comes up.
greengekko
uk
found bbc world news on channel 318 is that it lol tell me it is please :)
Sounds like a result .......... Channel numbers are largely irrelevant as you can move and delete Channels at will once you've scanned.
Just so I can go to lunch happy, give us the names of a couple of other Channels you've found. Ones that you can actually see a picture for, that is.
greengekko
uk
cctv news,ddtv
Yup. That appears to be Thor alright!
_http://www.flysat.com/1west.php
Hint: When giving Channel info, try to give some other parameters too eg
DDTV 12643 H 27500
That generally helps enormously.
Sounds like you might be nearly ready to try another Satellite.
Try Hotbird at 13E and/or Astra 2 at 28E
If you get both of those without further ado, then you've struck lucky!
sonnetpete
wordpress.com
Normandy, France
Yes, you have successfully aligned the dish to your due south sat.
:-party1
Now, apart from taking a break for lunch or going down the pub to celebrate, you may want to try and scan for more satellites. I'd suggest Astra2 at 28.2°E and maybe Hispasat at 30°W. If you get channels from both satellites it would suggest you are tracking the arc ok. You can of course then finely adjust the dish to maximize the signals all along the arc.
Oh, and please check that pole, if it isn't plumb you will be even more frustrated by the poor results you may get.
Edit : Seems great minds think something alike!
satelliteman
A nice result.
greengekko
uk
hi guys just to let you know ive successfully got all the sats sorted and patched me box so ready to go until i get a spider later thanks for all of your help :)
sonnetpete
wordpress.com
Normandy, France
Good result. Happy viewing
Blotty hell ............ you've gone from novice to expert in a couple of days.
I'm genuinely impressed :)
