Astra 2F at 28.2E: General Discussion
Not noticed anything different at all recently but then my dish is a bit of an overkill at the moment so perhaps I would not notice anything anyway. All 2F channels seem to be fine.
Very minor increase in SNR compare to my spreadsheet from December 2012.
But... the really big difference is a sizable increase in SNR of 1N transponders recently compared to 12/2012.
BTW, I wasn't talking about dust in the atmosphere. What I meant is if the satellite has passed through some dust it is possible the reflector has been scoured a bit.
S
Steve Steve
Well...something has changed.....about 30% Q increase of daytime signal (Humax).... (sorry guys I don't have any special signal measuring gadgets).... Just " say what I see"...kind of reports ....
M60
Northern England
I presume you mean the 1N UK spot TP's rather than PE ones - ex Astra 2B
Yes. I made the spreadsheet in expectation of band C and band D migration, and as we subsequently found out only band C transponders migrated.
I think keeping accurate records is more important than the equipment you are using. The idea is to show the trend over time, and relying on memory for SNR of 100 individual transponders one year later is never going to be accurate. But having nice gear that measures accurately to the nearest tenth of a dB is definitely a bonus if you want to keep track of minor changes.
BBC Wide Screen test transmission
Astra 2F @ 28.2 east
12552 V 22000 SD
id= 54190
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Friend of mine made script for enigma2, by running it receiver scans all frequencies on one or several birds. After process is done all the date could be found in one file. Than you can store data in excell/access format for future analyses.
Data looks like I've scanned 28,2*E last week.
S
Steve Steve
ok .Guys... Ch5 still ok here at 60Q... 100cm dish,,!......the turbo signal continues here in Munich... :-) ...hope it lasts ..??
Tururu
Assembled with recycled parts
Recycled as the owner.
If the script is for enigma2 public, it can happen.?
Si el script para enigma2 es publico, lo puedes pasar.??
Now every 7/15 days to review hand levels by recording them, could use the program you mention.
Ahora cada 7/15 días repaso niveles a mano dejando constancia de ellos, vendría bien el programa que comentas.
DB800S-HD, LNB Inverto Black Ultra 0'2dB, Antenna de 94cm (98x90cm = 0'692m²).
Levels in Madrid north zone today/Niveles en Madrid zona norte hoy 23-1-2014 19:00.
S
Steve Steve
2F UK signal here in Munich..... hitting a record high ......(My old 2D optimised 100cm dish ,no name cheap LNb)..Channel 5..At 90% Q ..80% S....(Hunax Freesat)......
This is the highest signal i can remember since 2F started..!!.....
cazhh
Elmshorn, Schleswig-Holstein
Same here. 16.7db, much higher than the 2A transponders. 2F PE now on 1N level.
S
Steve Steve
Yea....but does anyone know why ?......something must have changed...repositioning does sound to me.... to a reasonable explanation......as 2E is soon moving into position ......!......(if the high lasts that is )
hairybadger
Bricoleur
46.1N 6.4E
see sig
Yea....but does anyone know why ?......something must have changed...repositioning does sound to me to a reasonable explanation......as 2E is soon moving into position ......!......if the high lasts ..
Maybe the power has been cranked up to 11.
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
Signal extremely low here...Time to steer up this thing !
Just a thought, if they crank up the power of 1N and 2F they can make people believe the 2E beam is a lot tighter than it really is.
And here's me thinking you were no lover of conspiracy theories! :-rofl2
But it's not a conspiracy theory. Conspiracy theories require people to conspire.
mickwig
90cm Astra1 dish;
Same here, all time high, very nice!! And no conspiracy: according to SES the signal can vary from 33 dBW to 39 dBW at my location.
Fredrik M
Gibertini 125 dish, Inverto Black Ultra single aimed at 28.2 E, built in Philips TV receiver
Triax 110 aimed at Telstar 12 (15 W)
Landvetter (15 km E of Gothenburg), Sweden
bema, I looked at your graphs for today and it seems like you had nearly no signal on a couple of transponders around noon. The BBC transponder (11023H) suddenly seems to have been blacked out, while Channel 4 (11126V) faded out. What would cause such a black out like the one you had on 11023H?
