Astra 2E at 28.2E: General Discussion Part 1
Solly according to flysat yes it has moved to 2E
maybe tonight ses play low band of uk beam
before switch tp to 2e
welshman234
sky hd uk, 80cm kathrein dish,vu+ solo, humax f1 fox for hotbird 13
frankfurt
Just read in the digital Fernsehen Magazine here in Germany that the Rest of the BBC channels ie those Not already on 2 F will Transfer tomorrow Morning at 2am Western Europe Time
12480v still on 2a
unknow 11954h,11973v if it move to 2e
Is 11954H an active transponder? Checked this morning on 1.8m dish and not visible on the spectrum.
Pietclock
125cm
SE Germany 50°N/11°E
as a summary of all reports, it looks like this now:
11720H - 2E-E
11739V - 2E-E
11758H - 2E-E
11778V - 2E-E
11798H - 2E-E
11817V - 2A-S
11836H - 2E-E
11856V - 2E-E
11876H - 2A-S
11895V - 2A-S
11914H - 2E-E
11934V - 2E-E
11954H -
11973V -
11992H - 2A-N
12012V - 2E-E
12032H - 2A-S
12051V - 2A-S
12070H - 2A-N
12090V - 2A-N
12110H - 2A-S
12129V -
12148H - 2A-N
12168V - 2A-N
12188H - 2A-S
12207V - 2A-S
12226H - 2A-N
12246V - 2A-N
12266H - 2A-S
12285V - 2A-S
12304H - 2A-N
12324V - 2A-N
12344H - 2E-E
12363V - 2E-E
12383H - 2E-E
12402V -
12424H -
12441V - 2A-S
12460H - 2E-E
12480V - 2A-N
go at home
i see now 11185v signal data gone
it move astra 1n to 2e ?
Pietclock
125cm
@solly: it is completly gone ! TP is switched off. So 12.441V pretty likely really was a copy of it.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
@Pietclock
11934V is not 2A-North (must be South or 2E) :)
Retired Mod
www.timo.me.uk
Summary of my post from the Scandinavian thread:
I tested the Astra 2E Europe beam transponders on a 1.8m dish in Helsinki using DrHD F15 quality levels in the afternoon. As others have reported, 2E Europe is similar to 2A South quality wise but several dB lower than 2A North and a huge improvement on 1N PE1.
It seems a lot stronger then 2F Europe.
Retired Mod
www.timo.me.uk
go at home
It's now gone for me too. I was still there an hour ago when I checked!
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
They no doubt got that from the BBC's own article on the matter which was published a couple of days ago: It's posted here somewhere, but the Topic is fast-moving so I doubt it's easily findable!
Because the earth is a sphere and we measure distances on the surface of the earth. Spheres involved. And i can give it a numarical value. i know one angle (0.15 degrees attitude change) and one side of the triangle, ie the distance from me to the satellite. And i want to have the distance the beam moves on earth when the satellite rotates by 0.15 degrees around the z axis, ie the axis through the solar paddels. I think you are talking about a completely different problem.
Mod Note:
Can we have the trigonometry in a separate Topic, please.
@Huevos, please PM me the relevant Post #s and suggest a Topic Title and I'll find a suitable home.
Edit: All sorted, thnx.
woborny
Most probably 11...
12071H
12090V
12110H
12168V
12148H
12207V
12227H
12246V
12266H
12304H
12324V
Just got in and seen this list.
From this list - only 12207 and 12110 are still available on my 80cm dish here.
Before to day they were all available.
So that would suggest all but 12207 and 12110 are on 2As north beam. 2A north beam is simply not available here on the 80cm at this time of day.
dvdfilm
1.5m dish
spain
So far all migrations to 2E used the PE beam.It seems the spot beam will only be used for Freesat
I think we will leave any 2E Europe maps for a few days to wait until things settle down :D
Absolutely fascinating caching up with whats been posted whilst Ive been at work earning a few roubles today :D
Ah, I was wondering when you were planning to rummage down the back of your sofa for those old push-pins! ;)
