blademedia
- Jul 29, 2016
- Sky
- UK
Hi mosllam, I wont be doing comparison tests but the DH has the edge on the channel master, it has more gain and being prime focus less ground noise, this obviously gives you more signal,i am waiting eagerly to know the result and comparing ( CM vs DH )
we never had a chance to try any CM dish but we allready try some 20 years old 2.4 DH
DH 2.4 get better result compare to 2.1 PF local dish with same lnb ( black ultra with matched feed similer to invacom feed
i do not know - but i believe that CM and europian dishes has better quialty than the american one
CM 2.4 is a flat offset - while the DH 2.4 is a much deeper PF ( F/D = 0.38 )
To get the best out of any quality dish you need to use matched feed and LNB, sticking any LNB on a quality dish will give poor results compared to a good quality PLL LNB,
As you will know the PLL cost good money, you need time and patience setting them up, but once fine tuned your dish will shine.
