PaulR said:
Unfortunately, until you've been a member a bit longer and made a few more posts you won't have PM privileges. We had to introduce this rule to stop spammers abusing our forum.
Anyway, much better to post in open forum so that everyone can benefit!
No Problem - I didn't realise.
I've been developing Fibre to the Home solutions for years, primarily for international use and broadband applications. These are now working really well into the Sattelite area in the UK (an if used correctly you can deploy hybrid Data/Sat systems).
With a capabilty of delivering Terrabits of info...
Multiple TV & Data TX/RX all on one single fibre it is going to become more adopted.
A couple of highlights
Fibre cable Choice
Optical Fibre is fragile, no two ways about it is 125um in diameter (0.125mm) and it is glass. On its own it will be easily crushed, fractured etc.. Also, bend it too much and the light will be lost within.
Fibre cables are protected in many stages.. Primary coating (250um) Buffer (600/900um), Kevlar, outer jacket..
All these components matter, Outside deployment of Fibre cable is putting it under pretty extreme conditions.
Check all your cable is
* Crush resistant
* UV Stabalised
* Water Blocking (Water inside fibre cables is Not a good thing)
* Corosion resistant ( you will be suprised what some cables will use to provide crush resistance).
we generally supply 2 types.
* 3-3.5mm Crush resistant, bend resistant,UV stable water blocking cable.
* 5-7mm microduct cable (upto 1- 12Fibres, cable for direct bury or wall mounting)
The 3 - 3.5mm cable is neat and works well but we have found that areas of risk are better served with a rugged 5 or 7mm microduct.
Connectivity
Splitters
We have found that many of the 'splitters' used for Sat distribution are poor.
FBT (fused biconical taper) - essentially 2 fibres twisted together under heat, OK for 1x2 splitters but we are seeing them supplied as 1x8 and even 1x16... Not ideal as these are essentially just multiple 1x2's spliced together (high losses, poor uniformity and not really futureproof for hybrid data/sat systems).
Choose Higher quality Planar splitters (planar lightwave circuit), like an optical microchip
These give lower losses, better results and will be futureproof (as long as you source quality ones), they also perform better in extreme tempretures.
Connectors
Joining fibre you have a few methods.
(consider that the core of the fibre inside that 125um glass is just 9um... thats the bit you need to align) This is why it is critical you choose an effetcive connectorisation method.
Splicing (needs a £6k machine)
Mechanical Splicing (needs a £0.5-0.7k cleaving tool)
Feil Termination Connetcors (needs a £0.5-0.7k cleaving tool)
Pre-terminated Cables (get someone else to make the cable up for you).
Splicing is the best.. big installers should consider this option.
Smaller installers, you have the choice of pre-term or feild term. Feild term will reward quickly as cables can be made to length onsite quickly (all product in stock for fast deployment).
Housing Splices/Splitters/Connetcors
Choose solutions with cable management, IP protection (ingress protection) and UV stability.
We have been supplying a variety of solutions (64, 32, 24, 16, 8, 4 and even 2 Fibre capacity).
A few things to remember with fibre.
It does not like being bent tightly
Bend it smaller than a coke can and you will have trouble (30mm Radius). Opticreach cable can achieve 15mm and even 7.5mm radius.
It does not like being crushed.
Cable clip with care guys
It hates water
Make sure the jacket is UV stable and the cable contains Water blocking material
Don't feed after midnight...
Oh no. Thats Gremilins. Forget that one.
* Dirt is Fibres Enemy..
With a Core of 9um a wee bit of oil off your skin can mess up a connection. Clean your fibre connectors with care.
Fibre is going to be a key Element in tommorow networks... Learn to love it.
Want to know more - don't PM me ;)
(kstone
at opticreach.com)
Some snaps...
< 7mm Microduct containing 12 Fibres. Note required radius to enter wall.
3.5mm Duplex Cable (2x fibres for multi Sat Install)
< 64 Fibre Distribution Point with SPlitters
8 Fibre Distribution Point (150x100mm)
16 Fibre Distribution Box Inc Splitters
16 F highbrid Data / Sat Box (incl Splitters)
