First Setup - PLEASE HELP!!!
M
martz
Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e
Barnet, North London
Hi, i've been trying to put up my first system, the dish is up on the wall but i can't find anything, are the trees too high for where the dish is? the sky dish on the chimney gets a signal fine? the picture of the trees is taken from the height of the dish looking straight out are they too high, and the other pics shows how much higher the sky dish is
Basically i'm trying to find absolutely any sat with no luck, i'm using a 57cm kit from maplin, but i'm using a sky box to find the signal because the Comag SL35 it only tells you the signal for the specific channel on the specific sat you select.
http://img217.imageshack.us/img217/7593/pict02205xt.jpg
http://img217.imageshack.us/img217/5065/pict02219pd.jpg
Rob
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Did Sky put there dish on the chimney, because if they did it must have been for a very good reason, which could well be the trees especially when they have leaves on them.
Can you supply a picture which shows the height of the trees and the house.
sonic1
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
Hi martz!
Hard to tell from the pictures but a simple sat bleeper would help with the setup, I also think it would be worth saying I want to set the dish on 13e and use the comag and work to finding a specific sat not just any sat.
Use the list of stongest transponders in the stickeys to aid with the set up.
M
martz
i used the comag to select astra 1 but i cant find it no matter what, i'm gonna take a couple of photos and do a quick vid of the surrounding area
and yes the sky man put that dish there on the chimney in 99
Rob
Rob
Essex
If a Sky installer put it up there, instead of the "easy" option of putting it on the wall where you have put yours, it was because he was unable to get a signal from there.
They would not have gone on the roof if they did not have to common sense really, after all would you ! O-no
M
martz
sonic1
sonic1
Black Hole Team
Still hard to say martz but Rob has a good point!
Having looked at the pictures again a chainsaw may be a better investment
than a sat bleeper:-doh!
M
martz
okay cheers, so basically no foreign sat for me, my parents won't let me go on the roof and the trees are pretty high to cut down, oh well so much for a good school report.
W
wod
yorkshire
probably you'd get a signal if you use some t&k brackets and use a pole so the dish is above the roof ?
can you get astra 2 @ 28.2east on the dish ?
Rob
Rob
Essex
Very good in theory but a ba*ta*d in practice, and I don't think the local council will be to thrilled if they found out.
Also exposed to the wind up there, don't think so I'm afraid. O-no
M
martz
basically, i've just got back from my nans house where there's no obstructions, not even a sniff of a signal watever way i point it, when i connect it to my sky dish i get a signal about 75% both strength and quality, i don't know what i'm doing wrong and am frustrated right now.
Rob
Rob
Essex
I was doing this with my system yesterday and you only have to be a tiny bit out especially with a tiny 57cm dish, and you will get nothing as I found out yesterday.
If you are seriously thinking of doing this then get yourself a satellite finder, they are not expensive and are worth there weight in gold.
Have a look on e-bay, they must do them on there.
M
martz
tiny bit out as in 1/2 degree out? i'm only using the tv signal strength and it didn't even flinch
Rob
Rob
Essex
I'm not surprised, remember it's not just the east to west movement but at the same time you must make sure the up & down movement is right and I had a pig of a job doing it yesterday with the wife watching the TV for a picture which never came.
Even getting the Sky signal from 28.2 east is difficult with a 57cm dish, even when you can see everybody else's dish.
Get a sat finder, that's what there there for. ;)
Looks like the trees are much taller in the due South area than in the notch which the Sky dish is pointing above. You may have to consider putting the dish on the front, looking over the roof.
M
martz
cheers, i'm kinda getting fed up, i'm only 15 and am useless, maybe i'll get a finder and try again another day
sonic1
sonic1
Black Hole Team
Don't give up martz! Get back to us when you have a finder.;)
M
martz
is there anyway i can do it by using a compass and a protractor
sonic1
sonic1
Black Hole Team
Left school 15 years ago, could'nt use them then be fooked if I can now.
Like Rob said earlier don't forget you need to move the dish up and down as well as east to west.
Remember where there is a will there is a way;)
M
martz
i bought this sat meter, when it comes i'll try it out and probably ask for more help lol.
