Analoguesat said:
Mines the dark one too - although it seems to be a bit of a hybrid. Its got the styling of the 3600, and the innards of the 3000! The attachment shows the front panel arrangement of mine.
Setting the disecq switching up the first time was an interesting experience. Many swear words said until I realised I needed to change the settings in two menus!
T0 - Analoguesat
I have Echostar - AD-3000 IP Viaccess the same one you have
The Unit info.
Software version ESVCIAP 1000
the above software version is the latest version at
http://www.echostar-int.com downloaded from satellite ( OTA )
After upgrading my rceiver with above latest version " ESVCIAP 1000 "
I have a problem with the receiver when I input new Transponder frequency as follows :-
From Main Menu --> select # 5 Edit
Then from Edit sub-menu ---> select # 3 Edit Transponder
From Edit Transponder - sub-nenu ---> In this sub-menu on the Left
the list of the transponders frequencies - For example I have only four
transponders frequencies in the satellite " ExpressAir " When I try to Input new transponder frequency by prssing the blue button " Add TP " and inputting the frequency , the polarity , the sybol rate and FEC THEN
press the blue button " Scan " the receiver does not sacn for the new transponder frequency . In order to scan for a new transponder frequency
I have to delete one of the exisiting frequencies in the satellite frequencies list , Then the receiver will scan for the new transponder frequency . Before upgrading I can input many transponders frequencie as I like . So Do you know what seem to be the problem coming from ?
Best Regards
A.M.AL-MADHI
