Thanks for the info guys ..
I came accross this by softreel :-(bottom of the page)
..it appears to be a dedicated dvbs all format codec ...which covers all feed formats ..
Just a pity it doesn't do H264 ..so I still need one for HD ...but at approx £12 ....I might well buy it
Anyone used this one ?
It certainly looks the part ...but mpeg2 SD& HD only ...such a pity....no H264
rgds
VS
The Etymonix SoftReel MPEG-2 codec is a faster than real-time MPEG-2 video decoder optimized for single-core and multi-core systems. It enables smooth high-quality 4:2:2 playback of native MPEG-2 SD and HD video streams in DVB applications, Windows Media Player and other DirectShow-compatible products.
SoftReel's robust design makes it resilient to bitstream errors (e.g. from transmission glitches or scratched video discs). It has been tested on a wide range of processors and Windows operating systems for outstanding compatibility and stability.
The following table compares the main features of SoftReel version 2 with version 1. For a more complete product description, please see the detailed feature list.
Feature SoftReel v2 SoftReel v1
Maximum resolution 1920x1152 768x576
Media formats supported HD 1080p, 1080i and 720p
DVB (HD and SD, 4:2:2 and 4:2:0)
All 18 ATSC formats
SD (NTSC/PAL)
SVCD/CVD/VCD SD (NTSC/PAL)
SVCD/CVD/VCD
Aspect ratio 4:3 and 16:9 4:3 only
Performance Up to 5x faster than v1 Baseline
Multi-core optimized Yes, up to 16 cores (*) No
Deinterlacing Yes No
3:2 pulldown (telecine) Yes No
DVB applications Yes
(ProgDVB, DVBViewer, DVBDream, MyTheatre, AltDVB, TransEdit) No
Resilient to errors Yes No
CPU compatibility Wide range of CPU manufacturers Limited
CPU optimizations SSE2/SSE/MMX MMX only
Side-by-side 3D video display mode Yes (*) No
Field pictures and non-intra streams Yes (*) No
MPEG-1 video playback Yes No
Operating systems Windows 7/Vista
Windows XP MCE
Windows XP/2000/NT4
Windows Me/98/95 Windows XP/2000/NT4
Windows Me/98/95
Frame-accurate seeking in AVI files Yes Yes
One-click setup Yes No
Profiles/levels MP@ML, MP@LL, SP@ML, 4:2:2P@ML, 4:2:2P@HL, MP@H-14, MP@HL MP@ML, MP@LL, SP@ML
MPEG chroma formats 4:2:0, 4:2:2 and 4:4:4 4:2:0, 4:2:2
Output formats RGB32, RGB24, RGB565, RGB555, YUY2, UYVY, YV12, NV12 RGB32, RGB24, RGB565, RGB555, YUY2, UYVY, YV12
(*) New features introduced in version 2.30
