Or even a Gibertini 125.Great idea! And reference dish should not be 1,2m, it could be also 1,8m.
Yes, it perfectly stays on one spot.Did you rotate the boresighter
That could be true. But if you just lean LNB little bit down, than you also need to lift it up little bit to make sure LNB's Phase center is located where antenna's focal point is.If you move slightly down lnb on channel master 1.2 you will got better snr
Anf why is it that it should be much lower?So, CM1,2m is clean and some homework could be done with it. First lesson, even without precise measurements, is that original LNB holder holds LNB at the wrong angle! I suspected that, and now got evidence. You see red dot, it is exactly in the middle of the dish, but should be much lower.
Add: And I suspect that other CM1,2m owners have same issue.
It is oofset geometry. On the attached picture I draw red line, which represents middle of the dish looking from satellite, but that will be lower then antenna's geometrical middle. That what I was trying to say in this thread.Anf why is it that it should be much lower?
Rimants , thats what I was thinking to the first time , maybe the feedarm was bended by this old mistreated dish .
So I drove to satshop Hamido (we've been there together) and tested at a new Triax and SAB dish with exactly the same result .
Both brands seem to use the lower section of the dish for the attachment of the feedarm through the dish .
Then I drove to my satfriend PaulvR here in town and tested it at a fiber Hirschmann dish with the feedarm under the dish .
There the spot was following exactly the edge of the dish .
Focal point is no problem, but aiming point is out 140mm. At the same time, remember, we found out another day that IBU's illumination angle is 84*, but opening angle of CM120 is 80*, so even if LNB slightly out of direction we still getting good signalspectacularly wrong for the focal point to be 140mm out, maybe 5 to 20mm but 140mm?
I don't understand this at all. Do you mean to compare an offset with a primary focus dish perhaps? Or maybe a "conventional" offset dish with a $ly type offset dish?
I believe that Gregorian, and the other dual reflector type Cassegrain, benefit in three areas. Firstly having a longer focal length gives extra gain, Secondly altering the optical characteristics on the secondary reflector gives greater selectivity and thirdly, but least, by placing the LNB in a position where it can accessed more easily.
