If we are both going to have a go at this, we might help each other. I think maybe you'll need a slightly bigger dish down in Malaga than I will half way up Portugal. I checked the coverage map which took me a while to find as Intelsat now call it "IS-907 at 332.5º E" and I was searching for 27.5w (and the lyngsat site seems to have out of date map links). Anyway the image is now at exnetapps.intelsat.com/flash/coverage-maps/images/907-332s1.jpg
Comparing that map with dishsize info from Analoguesat on selkirkshire.demon.co.uk/analoguesat/dishsize.html (needs the www. prefix) it seems that while I just squeeeze into 60cm being on the borderline of 48.6dbw, down south in Malaga you might need 75cm or 80cm as you will be around 47dbw I guess.
I understand that on your Sky box you can still get the HD version of ch 5 and presumably any pay channels you've signed up for, but I gather you will not get any more FTA channels than Freesat boxes when they switch to 2E / 2F?
For me it is BBC 1, 2, 3 and 4 that I watch more than anything else, so if I can find a way to channel hop between those from the comfort of my armchair, I'll feel a lot happier than waiting for buffering and loading from the various internet routes which I've tested thus far (filmon etc).
I managed to find out that PMT stands for Program Map Table, but I haven't yet figured out what "clines" are?
It's great to hear that the Biss code business is very easy on you other box, that's a relief, I may ask for help if I get stuck.
dantis1 said:
I am in the same situation as you, due to the fact I am located near Malaga, a seperate small dish and the TM 5402HD seems the way to go. The Openbox S10 that I currently use does not seem to like scrambled PMT's so its out. As you say the relatively small investment of £140 may be worth it, although the BBC could change the encryption, who knows?
I have Sky+ HD so will be less affected than others, but I would like ITV HD and BBC1 HD at least.
The setting-up procedure will probably be similar to my S10 which currently runs two clines for Canal+, Sky.it, Sky.de etc etc, I am a bit of a newbie myself but it all seems quite straightforward. I have decoded two channels on 26E using BISS and the S10 and it was very easy indeed.
