- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
you could always install it at a slight angle, around 10 degrees off centre.
Eureka !
If you grease one side of the new TV , then apply the right pressure (in the right places) you could obtain the nirvana of the curved TV within the space available. It has to be convex though (to the viewer side) so get some clean plimsolls on otherwise you will be cleaning the screen when you could be watching 4k definition.
Easy does it
