blademedia
- Jul 29, 2016
- Sky
- UK
Install a vpn and get on with life, if someone wants to track you they will with/without your permission ;)
I attached a photo ..and youtube is missing from the Tiles along the bottom of the screen ?...so I am I bit confused about this.YouTube will only disappear on older models from what I can see, use your smart remote to access it, manual scan is a bit of a mess around but at the end of the day its not a tbs card, ive not and wont be using a motor on mine, cant help sorry
So what you are saying is ...the option to activate youtube is no longer available on an OS tile by clicking ..Put the normal remote back in the box and use the smart remote, its called a smart remote for a reason , ive just done a small video to get to youtube, as long as you can talk its as easy as this
MVI 3481
Yep ..just tried it Blade..What I am saying the easiest way to use the remote is by using the smart option, they might be a way to customise the tiles, but talking to the remote does the job
I do that and I don't have a magic remote, especially when it fails to do the command I have just pressed.Yep ..just tried it Blade..
..and it does indeed get me to youtube..
But ..it may just be my age showing..but I feel so bloody foolish shouting at a remote..
lol
NOOOoooooooooooooooooThe worst bit will be when the Remote shouts back at you. 'cos that's what'll 'appen.
lol
Thanks Jimmy ..I've got a LG43UH661V and I had to manually add Youtube, it's in the premium section of the content store.
In old LG 4K (UHD), 2 years, only has DiSEqC support for 4 satellites.Is anyone driving a motor directly from an LG smart TV ?
