epg audio channel
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
Take a picture or three of the dish (front/rear/near/far) and post them.
It might be that someone here can identify an immediate fault on the install without you trying things to improve reception (and making it worse)
i just think its slighty off target so it needs moving a little bit
That is the start of a slippery slope. Like badly laid block paving, once it's down there is nothing you can do to improve it.
Retired human
I think we all agree that the dish needs a nudge.... Go do it!
John Pykett
Persona non grata
John Pykett
Persona non grata
well back here again well i lost tru tv because of rain today so im thinking maybe i could get a zone 2 dish to increase the quality
You should not be losing any channels in anything short of a monsoon like downpour or wet snow on the dish these days now all the old lower powered birds are out of service.
Ergo your dish alignment is suspect or the lnb skew has been knocked.
Or the cable is damaged and the cable is full of water - Ive seen that in the past!
I use a Zone 1 dish a fair bit further North than you and only get brief outages in really torrential rain. Using Zone 2 won't prevent that - Even my 80cm and 1m dishes are affected in severe conditions.
Edit: Dang that @Analoguesat! :-lol
John Pykett
Persona non grata
not all most of fine again its the european beam channels that have problems still so yeah maybe getting zone 2 will help
You shouldn't need a Zone 2 dish in the Nottingham area. Something else is wrong, most likely the dish alignment or LNB skew. Other possibilities are faulty LNB or faulty LNB.
No. Won't solve the problem.
qv All replies, in the round.
John Pykett
Persona non grata
i think its not skew. first i think its water on the white thing on the lnb then next weekend ill check alignment.
Spray furniture polish on your white thing .... repels water fairly well.
John Pykett
Persona non grata
Is that thing called a feedhorn or something?
Furniture polish, wd40, gt85, plusgas, whatever you have that repels water.
John Pykett
Persona non grata
No, it's just a dust and water cap.
The feedhorn is what it's covering.
Edit: Not again ..... :-buttkick
Need to type faster bud :-rofl2
John Pykett
Persona non grata
well the european beam channels are back so im guessing the water came off the lnb cap?
