Second coat applied yesterday and is fully cured/dried this morning so good to go to fit the Elite logo.
Another tip if repainting you antenna
@moonbase ... don't over fill the sponge type roller and try to roll out any thick paint covering onto an unpainted bit of the reflector so as to achieve a covering that is not too thick.
Using a heat gun, the reflector & logo transfers were very slightly pre-heated as per Elite's recommendation, to ensure trouble free application, which proved to be the case.
Nearly time to lower the 1.8 for any mount maintenance, bearing checks etc before installing the 2.2 sometime next week weather permitting.
