OCTAGON SX88 H.265 HEVC HD
new receiver will be on market new octagon
small box, but very good
hardware blindscan
multistream, without parameter enter
just ch search enough for multistream on sx88
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Available next week for 75 Euros...anybody tempted?
Main features:
- H.265 / MPEG4 - HD / SD, DVB-S2 Multistream Tuner
- Multistream Root, Gold, (PLP, PLS) T2MI Support without Parameter Input
- Hardware BlindScan (Low Symbol Rate Support)
- Stalker, Kodi (XBMC), Xtream IPTV
- .m3u, YouTube, RedTube
- 2 x USB 2.0 ports
- 4 digit 7 segment display
Features:
- Linux OS operating system
- WebIF & FTP access
- Conax card reader
- Recording & TimeShift (* optional)
- Network 10 / 100Mbit LAN
- WiFi (WLAN) + 3GB Model Supported by USB Ports
- DLNA Player Support
- Unicable & FastScan Support
- DiSEqC 1.0, 1.1, 1.2 and USALS Support
- EPG - Electronic Programmer
- High-Resolution OSD UI User Interface
- 4x Programmable Keys on Remote Control
- Subtitle & Teletext Support
- 0.5 W Standby
- Dimensions (LxDxH) 120mm x 80mm x 25mm
Front:
- 4-digit 7-segment display
- LED indication (red / green)
- IR sensor (IR receiver)
Back:
- H.265 HD DVB-S2 LNB input
- Network 10 / 100Mbit connection
- HDMI output
- Digital Audio jack
- AV - AV jack - jack to RCA
(right):
- LED / IR (external display or IR infrared receiver) Interface
- USB 2.0 port
(left) side:
- USB 2.0 port
- 12V DC power supply
- RS232 connector
included:
- Receiver OCTAGON SX88
- Remote control
- 2 x batteries
- Instruction manual (German & English)
- HDMI cable
- IR Infrared Receiver
- AV RCA Jack Cable
Looks very interesting.
I haven't bought any toys for ages, so might see what's in the piggy bank.
As a Yorkshireman, I'll wait for the price to plummet, though!
PS can another staffie shift this to a more appropriate sub Forum?
I'm busy watching Masterchef :D
Edit: Done. By me. 12 hours later :rolleyes::-funbounce
Maybe worth adding to my collection for the H265 & Hardware Blind Scan :)
I find that there's something inherently wrong about "small" receivers. I much, much prefer full size ones.
Does look interesting though, especially for the price. Doesn't seem to mention CPU though...
I assume blind scan with being hardware will work from release and not have to be 'added' in a future update like the 4K model!
MCelliotG
Thessaloniki, Greece
This has to be another closed source firmware where all the known MIS data (pls modes, codes and stream ids) are pre-stored, leading the users to believe that the tuner actually blindscans a PLS scrambled transponder. Same line as the Denys receiver and the upcoming Edision. I'll see further to this receiver in the coming days, but I'm 99.9% sure this is the case.
stephan94
Bavaria
stephan94
Bavaria
yes,beta tester
Can you select a part of the Ku band to Blind Scan as this a much faster way to find active transponders for example:-
Start 10950 Stop 11200,
-------11240 to 11700
-------12500 to 12750
Or does it just scan the entire band 10.7 to 12.75 as this can be very slow.
Huh. Priorities, eh?
What I'd welcome is knowing how to get a Discount! ;):D
A true Yorkshireman! I'm up in Whitby at the mo, and like a bargain!
stephan94
Bavaria
yes ,only with this way.
it is not fast but it is not slow.
depending on the satellites the result is different.
Sometimes when you switch from one polarity to another it lasts a long time?
why? I don't know
if you ask to look for the MIS (multistream T2MI) the blindscan is slower.
stephan94
Perhaps you can tell us how good or bad the blind scan and other features are? Thanks
..... and also please stephan a screen grab of the lnb LO choices, especially Ka band LO options ie: 17.250 / 20.250 etc . Also the C band LO choices. Has the lnb LO menu got a "User" input option, which is a real need for the enthusiast that might want to use this receiver ..... and just as important- will it actually perform a blind scan correctly on the selected LO input choice.
T.I.A
stephan94
Bavaria
to his personal settings (eg KA Band)
thanks stephan that's a big help. There have been problems in the past with some Technomate receivers that had the LO "user" option in the menu to do blind scans on various Ka bands and C band lnb's that used LO's of 5.76 or lnb's that do extended C-band frequency coverage like 3600 - 4800 etc but when you pressed "Go" or whatever, the rx just failed to start or crashed . Do you know of any beta testers that can run a successful blind scan on these less common lnb and band choices.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Video link showing search menu
