Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
What's the problem?
mrbahr
Amiko Alien
Egypt
i need value for both frequencies 3685 L 15284 & 3665 L 14990 at Astra.conf
thanks for replaying Captain Jack
See my file attached.
  • astra.txt
mrbahr
Amiko Alien
Egypt
not working for me , however 3685 L working great
Do you have good signal?
mrbahr
Amiko Alien
Egypt
yes very good signal and 3665 L better than working tp
mrbahr
Amiko Alien
Egypt
3665 L 14990 data analyze
  • astra --analyze.txt
Your data analysis looks OK - same as mine. Could be an issue with IPTV channel setting?
mrbahr
Amiko Alien
Egypt
thank you so much captain jack for your interesting
i will try to make new iptv channel and try again
mrbahr
Amiko Alien
Egypt
working Now thanks Captain Jack thanks MCelliotG
frankviana
Satellites/tv
Brazil
Please, I need help with this t2-mi channels 40.5º W
This is only 1 test (PLP 103, PID 64):
astra sm config:
#!/usr/bin/astra
log.set({ stdout = false, debug = false, syslog = "astra", })
f4000plp103 = make_t2mi_decap({
name = "4000H SID 0x320",
input = "http://127.0.0.1:8001/1:0:1:320:3A2:0:C7A0FA0:0:0:0",
plp = 103,
pnr = 0,
pid = 64,
but first, astra-sm analyzer:
new data: dreambox edit:
PLP 103
PID 64: C1540 (40 HEX)
There are 2 channels T2-MI (TRECE and TRECE2), transponder: 4000 H 3750
Decap process don't work.
I need help, thanks
frankviana
Satellites/tv
Brazil
But my test using OpenPLI 6.0 and Vu zero 4k
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
damn these russian satellites.... they re using more and more of this moron-ish encoding of T2-MI :-nutkick
MCelliotG
Thessaloniki, Greece
Try with pid 4096, I doubt pid 64 is used for t2-mi!
frankviana
Satellites/tv
Brazil
But why 4t2 analyzer show PID 64? I tried with 4096 too and not valid packages using astra-sm
frankviana
Satellites/tv
Brazil
Now using pid 4096
Fidu7
Gibertini 125
Luzern
PID 64 works but I think c:150040 is right
MCelliotG
Try with pid 64 and make sure both flags K and P are selected as well! If you don't succeed, record a 2 minute TS file from the fake channel you created (I suppose you created this correctly) and send it to me to analyze it myself!
frankviana
Satellites/tv
Brazil
Wow... this only : to work..
Thank you a lot!!!!
root@vuzero4k:/usr/bin# astra --analyze "t2mi://#t2mi_pid=64&t2mi_input=http://127.0.0.1:800...C7A0FA0:0:0:0:"
May 21 20:04:27: INFO: Starting Astra SM 0.2
May 21 20:04:28: INFO: [t2mi/analyze] L1-current: PLP 103 (Data Type 1), group 3 (*)
May 21 20:04:28: INFO: [t2mi/analyze] selected data PLP 103 (auto)
May 21 20:04:28: INFO: PAT: tsid: 3001
May 21 20:04:28: INFO: PAT: pid: 16 NIT
May 21 20:04:28: INFO: PAT: pid: 5010 PMT pnr: 6001
May 21 20:04:28: INFO: PAT: pid: 5020 PMT pnr: 6002
May 21 20:04:28: INFO: PAT: crc32: 0xED4C8684
May 21 20:04:28: INFO: PMT: pnr: 6001
May 21 20:04:28: INFO: PMT: pid: 5011 PCR
May 21 20:04:28: INFO: PMT: descriptor: 0x0C0480B48168
May 21 20:04:28: INFO: PMT: Maximum bitrate: 12756
May 21 20:04:28: INFO: VIDEO: pid: 5011 type: MPEG-4 AVC/H.264, ISO/IEC 14496-10 (0x1:cool:
May 21 20:04:28: INFO: VIDEO: Stream ID: 1
May 21 20:04:28: INFO: VIDEO: descriptor: 0x020322445F
May 21 20:04:28: INFO: VIDEO: descriptor: 0x060102
May 21 20:04:28: INFO: VIDEO: Maximum bitrate: 12627
May 21 20:04:28: INFO: VIDEO: descriptor: 0x28046400283F
May 21 20:04:28: INFO: AUDIO: pid: 5012 type: MPEG-1 audio, ISO/IEC 11172-3 (0x03)
May 21 20:04:28: INFO: AUDIO: Stream ID: 2
May 21 20:04:28: INFO: AUDIO: Language: spa
May 21 20:04:28: INFO: AUDIO: descriptor: 0x030167
May 21 20:04:28: INFO: AUDIO: Maximum bitrate: 492
May 21 20:04:28: INFO: SUB: pid: 1045 type: Private PES, ISO/IEC 13818-1 (0x06)
May 21 20:04:28: INFO: SUB: Stream ID: 5
May 21 20:04:28: INFO: SUB: Maximum bitrate: 25
May 21 20:04:28: INFO: SUB: descriptor: 0x59087370611000020002
May 21 20:04:28: INFO: PMT: crc32: 0xCAE02A7A
May 21 20:04:28: INFO: PMT: pnr: 6002
May 21 20:04:28: INFO: PMT: pid: 5021 PCR
May 21 20:04:28: INFO: PMT: Maximum bitrate: 4071
May 21 20:04:28: INFO: VIDEO: pid: 5021 type: MPEG-4 AVC/H.264, ISO/IEC 14496-10 (0x1:cool:
May 21 20:04:28: INFO: VIDEO: descriptor: 0x020322485F
May 21 20:04:28: INFO: VIDEO: Maximum bitrate: 3942
May 21 20:04:28: INFO: VIDEO: descriptor: 0x28044D401E3F
May 21 20:04:28: INFO: AUDIO: pid: 5022 type: MPEG-1 audio, ISO/IEC 11172-3 (0x03)
May 21 20:04:28: INFO: AUDIO: Maximum bitrate: 329
May 21 20:04:28: INFO: PMT: crc32: 0xF56A5813
May 21 20:04:28: INFO: Bitrate: 5139 Kbit/s
May 21 20:04:29: INFO: SDT: tsid: 3001
May 21 20:04:29: INFO: SDT: sid: 6001
May 21 20:04:29: INFO: SDT: Service: CANAL TRECE
May 21 20:04:29: INFO: SDT: Provider: CANAL TRECE
May 21 20:04:29: INFO: SDT: sid: 6002
May 21 20:04:29: INFO: SDT: Service: CANAL TRECE 2
May 21 20:04:29: INFO: SDT: crc32: 0xFAFC8303
May 21 20:04:29: INFO: Bitrate: 5583 Kbit/s
[31mMay 21 20:04:29: ERROR: CC: PID:17=1 [0m
May 21 20:04:30: INFO: Bitrate: 8392 Kbit/s
May 21 20:04:31: INFO: Bitrate: 5582 Kbit/s
May 21 20:04:32: INFO: Bitrate: 8354 Kbit/s
[31mMay 21 20:04:32: ERROR: CC: PID:16=1 [0m
May 21 20:04:33: INFO: Bitrate: 5582 Kbit/s
May 21 20:04:34: INFO: Bitrate: 8395 Kbit/s
May 21 20:04:35: INFO: Bitrate: 5586 Kbit/s
May 21 20:04:36: INFO: Bitrate: 8351 Kbit/s
May 21 20:04:37: INFO: Bitrate: 6669 Kbit/s
May 21 20:04:38: INFO: Bitrate: 7308 Kbit/s
May 21 20:04:39: INFO: Bitrate: 8358 Kbit/s
May 21 20:04:40: INFO: Bitrate: 5579 Kbit/s
May 21 20:04:41: INFO: Bitrate: 8396 Kbit/s
May 21 20:04:42: INFO: Bitrate: 5584 Kbit/s
May 21 20:04:43: INFO: Bitrate: 8351 Kbit/s
May 21 20:04:44: INFO: Bitrate: 5586 Kbit/s
May 21 20:04:45: INFO: Bitrate: 8396 Kbit/s
May 21 20:04:46: INFO: Bitrate: 5578 Kbit/s
May 21 20:04:47: INFO: Bitrate: 8394 Kbit/s
May 21 20:04:48: INFO: Bitrate: 8356 Kbit/s
May 21 20:04:49: INFO: Bitrate: 5580 Kbit/s
May 21 20:04:50: INFO: Bitrate: 8396 Kbit/s
May 21 20:04:51: INFO: Bitrate: 5586 Kbit/s
May 21 20:04:52: INFO: Bitrate: 8356 Kbit/s
May 21 20:04:53: INFO: Bitrate: 5582 Kbit/s
May 21 20:04:54: INFO: Bitrate: 8391 Kbit/s
^C
May 21 20:04:55: INFO: [main] shutting down
