Top Tip T2-MI reception on E2 STB with SDG image - A complete step by step guide
MCelliotG
Thessaloniki, Greece
I'm glad this was sorted! Happy viewing!
MIDOVIE
AMIKO ALIEN 8900
CAIRO
thank you so much
it works for me (amiko alien 8900 HD )
but i have a small problem only
3685 L 15284 works great
but 3665 L 14990 not working when trying to do same steps is there any help please thanks
CAN YOU HELP ME AND SEND ME A LINK FOR YOUR RECIVER BACKUP WITH MATCH TV ON EXPRESS 53E
You would need a 3.8m dish as a minimum to receive c-band from 53 East in Cairo.
You're posting in the wrong section then.
MIDOVIE
AMIKO ALIEN 8900
CAIRO
i can`t do the tutorial some thing wrong all i want an enigma backup i use amiko alien 8900 to match tv on express 53e
Go back to the beginning and follow the instructions EXACTLY. We are a technical forum and dont give users the easy route out. If you cant get it going from the instructions supplied then you have to do without.
Or put the money you will have saved to date into buying into a useful piece of equipment, like a 3.8m dish and C band LNB.
Lexzie
TBS 5925 USB-tuner
The Netherlands
3. Getting the feed channel
Every Enigma2 receiver when it gets tuned to a T2-MI transponder will not download the channels directly (although this automation has to be implemented in the near future). Instead the tuner will lock and download a data channel. In the following example we used a T2-MI transponder on the C band of Express AM7 satellite on 40E.
In this image you can see that this frequency (3685L) is tuned normally with the internal tuner.
Now, scanning the frequency downloads the data service (it might take a while).
This does not work here. I'm using a VU+ Zero 4k which can lock and scan other Multistream (4.8E, 5W).
I'm testing on Astra 4A at 4.8°E, 12188 H/30000.
I have signal + lock but when I want to scan I get no result (so also no data channel).
I tried adding the services manualy, but no results.
What can I do to get these channels?
T2-MI is *not* multistream. You can have T2-MI encapsulated into multistream as well as not.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
You need to install astra-sm and add as bouquet manually for zeonbud. I like watching the M1 ukraine music channel from 4.8e.
Lexzie
TBS 5925 USB-tuner
The Netherlands
This one is Multistream (according to Lyngsat and Flysat). But I also noticed I have signal and lock without Transponder stream type to 'Multistream'.
I have installed astra-sm and tried adding the bouquet manually. Perhaps I did not do that right, can you give me some tips?
Yeah, this one is both, multistream and T2-MI - a double whammy. I can't really help you with ZeonBud as I don't have it configured but my Solo2 and HD51 both downloaded a "dummy" data channel from other T2-MI transponders, so not sure why the Zero isn't doing it.
Perhaps someone already has a ready made list.
mike1
GT Media V7SX
what is your box? i can give you files image?
Lexzie
TBS 5925 USB-tuner
The Netherlands
SatSearcher
West Yorkshire
I'm also having this problem with my Octagon SF4008, it doesn't download a data channel, added it manually but it doesn't seem to work like that. Anybody know a work round for this?
mike1
GT Media V7SX
Zeon bud Step 1 (Astra 4.8e T2MI)
telnet or ssh your box
Step 2
opkg install astra-sm
init 2
init 4
(init 2 & 4 will enable you to write over to the lamedb while the box is running)
Step 3
Open ftp client and over write files to the same path areas in the zip
/var/etc/astra/astra.conf
/var/etc/engima2/lamedb
/var/etc/engima2/userbouquet.zeonbud.tv
Step 4
reboot
Step 5
Go to the Zeonbud Bouquet!
works on vix and openpli tested on Octogan Sf4008 and Mutant 51.
  • T2mi 4.8e.zip
