Es’hail 2 25.5e
stephan94
Bavaria
I have everything edited as shown but i just get this when starting CS:
Am I missing something obvious here?
Take this one:
This crazyscan works as it is, you have nothing to change.
good luck
stephan94:)
stephan94
Bavaria
I managed to lock a SR of 100 :)
SatSearcher
West Yorkshire
Many thanks Stephan, that works a treat! Although I'm still a little confused as to how, as looking at the ini files, they look to be configured the same as the ones I was already using, so still scratching my head a little! But thanks again!
fereshte
Bulgaria
2,30m prime focus dish with 3 LNBs - C ( Linear plus Circular ) and KU ( Linear ) ; 2,05m prime focus dish - KU circular and in future hopefully - ka band - 103E - 50W ; Octagon SF4008 UHD ; Edision Primo IP ; Inverto Flange white series ; Invacom quad; 36" motors; Especta and Moteck satellite positioners.
Bulgaria
Hi guys ! I bought a BOWEI LNB 10-10.7 GHz from aliexpress , then put it on my 230 cm prime focus dish but not in the center of the dish, alongside the rest multifeed LNBs. Then the issue began - on the receiver what I have to put in the two LOF lines and threshold ( it is enigma2 receiver octagon 4008 uhd ). I wrote 9750 there but no signal , then on an another receiver not enigma 2 I put 9750 or 10050 ghz lnb freq but no signal on 10493H2000. Here I read that the symbol rare changes often and perhaps this is the reason why I got anything. In what position I have to rotate put the LNB - in the way that the main LNB is rotated in its position or ? It is a new thing for me to setup such a LNB in these low ku band frequencies. Thanks if someone can respond to solve my problem ! According to flysat there is one stable frequency - promo channel of Eshail sat.. Is that correct ?
mar-val
Slovakia,Zilina
I think , on LNB MUST be LO parameter.
BOWEI LNB 10-10.7 with google search shows LO 9Ghz.
fereshte
Bulgaria
Bulgaria
Then 9750 GHz is the right LNB freq, I rotated the dish - not a clue on 10493H2000 - then I read here that this frequency's symbol rate very often changes. I do not have a PC Receiver, my receiver is octagon sf4008 uhd.
9750 will not be the correct local oscillator to get 10.493GHz.
Try a manual frequency input of 11.493 using the same parameters of s/r
fereshte
Bulgaria
Bulgaria
All right, I am going to put 11493 but the oscillator remains as usual - Universal LNB or the numbers have to be different ? Thanks for you help.
If you cannot use a custom lo of 10GHz then with universal settings add 250 to the 11493. Though if the software cut off in the receiver occurs at 11700 you will need to work the calculation with the same conversion on the 10600 upper band.
dwabbit
zgemma x2 plus 2x 1m dishes and 1 80cm dish for eshail 2 for ham radio
lincolnshire
2 stations at 66ks
123998123999
stephan94
Bavaria
With luck, I was busy receiving Es'hail2 when a radio amateur took over from ISS.23°5E_1905071647_10484-10534 H.jpg23°5E_1905071647.jpg23°5E_10498_H_1.jpg23°5E_10498_H_4718.jpg26.0E_10498,102_H_333_(2019-05-07 16.33.54)_dump.ts_20190507_163855.605.jpg
Now is off,but I caught a transponder(11495 H,1000,1/2,S2) which uses the HEVC codec with low symbol rates?
It's worth monitoring these transponders,because tests are done here for the use of all sorts of parameters,as shown on this topic or on other sites.It seems to me that's the purpose of these "Amateurs" :) It's actually the place where these "amateurs" meet with us,dxers,or rather, where the last ones are expected to come... :)
stephan94
Bavaria
10497,4 H 333 2/3
G7JTT-JOHN
stephan94
Bavaria
10498 H 333 2/3
G7NTG
stephan94
Bavaria
10495,8 H 500 3/4
ON1WW
stephan94
Bavaria
After replacing my old LNB IBU with a new Edision QSL-4, I have the feeling that the very close and very small SR can lure better.
Just a feeling; I did not have a timer with me
Both frequencies can even be seen in the screenshot of CT1BYM's screen
stephan94
Bavaria
10494,7H sr1000
DVB-S2 QPSK2 2/3
G8LES26°0E_10495_H_1.jpg26°0E_10495_H_5126.jpg26°0E_10495_H_5212.jpg26°0E_10495_H_5027.jpg26°0E_10495_H_5230.jpg
aceb
Prof Tuner 7301 /
Sussex
Asking for a friend, what is the smallest dish being used with success in NW Europe, will an 85CM mesh work?
stephan94
Bavaria
Today my record,
an image with a sr of 125
10497.215 H
sr 125
DVB-S QPSK 3/4
HB9IAM
@aceb i think , with 85cm is OK
stephan94
Bavaria
PA3AXO
10495.921 H
SR 500
DVB-S2 QPSK2
2/3
