Express 80 (will be 80E) & Express 103 (will be 103E)
Press release about Express-80 on the RSCC site:
C- and Ku-band coverage maps:
dreamsat
germany
today is full power :cool:
3536 R
DVB-S2/8PSK
MPEG-4
T2-MI 15280 3/4
first transponder on c band
anto@
italy
new Sr 20575 wimax left right
Express-103 at 96.5°E must have taken over all services of Express-AM33.
Because according latest TLE, Express-AM33 is moving 1.0°W/day, near 94.5°E now.
dreamsat
germany
New transponder at 11044 V 45000 1/2 AOL Service
dreamsat
germany
10982 V 35000 is on
dreamsat
germany
current scan
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
For the first time I have seen a feed here - off again now.
11619.5 V 2500 3/4 DVB-S
dreamsat
germany
two new data transponders
11651 V 2350 1/2
11656 V 2070 1/2
on the 10981 only one radio program is available
dreamsat
germany
10981 V 35000 New Channels
First test with neumoDVB at 80.0E with the 6903x card. Strong signal.
dreamsat
germany
I went there too. my values with 3.70m
96.5 E@ Express 103
There will be extreme reception enthusiasts on this forum, now that there are many members from several reception areas. Perhaps one of them could receive Express-103 at 96.5E. I would ask the one who arrives with the antenna at this position to try to lock the upper band frequencies.
If interested in an update on the transponders from this satellite, I post what I found at 96.5E.
12509 V,2859,4/5,32APSK-unlock,
12514 V,6294,4/5,32APSK-unlock,
12521 V,2600,4/5,32APSK-unlock,
12523 V,867,4/5,32APSK-unlock.
ps_Too bad @RimaNTSS's antenna doesn't "travel" in orbit. It would have been a good opportunity to check these frequencies,especially since it is placed in a favorable area for far eastern satellites :)
dreamsat
germany
the 10998 H 20000 has also a 256 APSK Mode
I revisited 96.5E. Nothing special but the same questions that were not answered, i.e., who can confirm the existence of muxes in the upper band?
The signal is relatively weak, so only with IQmonitor, was I able to capture and lock these muxes.
I would say that reaching an extreme of the arc is in itself a (mechanical) performance and not the reception as such since there are very few users who report such ...extreme reception (@moonbase, perhaps this should be included in your list of extreme receptions(?:)).
@dreamsat, if you have reached 96.5E, please check the upper band where some transponders you see on my spectrum are, probably Data.
... since there are very few users who report such ...extreme reception (@moonbase, perhaps this should be included in your list of extreme receptions(?:)).
@satesco
Although I have access to 100.5E, 152.0E, 160.0E and 166.0E on the Eastern global grid, I do not have access to 96.5E at the moment.
If things change and I get access to 96.5E I will take an IQmonitor scan and get back to you with the results.
dreamsat
germany
i have receive from 88,0° east to 61,0° west
Thanks for trying,@moonbase, and I really wish you could catch Express-103 as well, but I'd rather keep dying to be sure if these muxes in the upper band are really at this position or 97.3/97.9E.
At such a low elevation, it is tough to identify the position with a small antenna.
Fingers crossed that you make it. :Y
adonis1
96.5 E@ Express 103
Τhese frequencies comes from SES-8 / SES-12 @ 95°E
