Astra 2F: Pre-Operational Discussion
Shiny new Thread.
Be good.
Lets try and keep this one factual!
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
MULTI TV GHANA now on ASTRA 2F WEST AFRICA BEAM
but with different symbol rate
FREQUENCY[background=rgb(254, 254, 254)] (12522) and new [/background]SYMBOL RATE[background=rgb(254, 254, 254)] (19531)[/background]
Pedro0102
Motorized system mainly aiming @ 28.2/28.5E
Famaval 3.1m
Invacom quad
Lisbon, Portugal
Reports no a Portuguese forums show prof of 2F reception with a 1.3 m dish near the city of Guarda (more concretely Trancoso)
-http://www.dragteam.info/forum/noticias-assuntos-gerais/168399-astra-2f-8.html
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
Amazing ... it does seems genuine !!
Has anyone seen any signs of eg Changes to strength of 11023, further Tests, migration overnight?
This hiatus is somewhat tedious!
Bengt
1,8m PF dish (situated on balcony),Invacom Quad or Inverto LNB (it varies), Sky Digibox, Humax Foxsat HD receiver, TBS8922 card.
Trelleborg (swedish south coast)
Hi
About 11.17CET I noticed that the 11023H signal disappeared completely for about 5 seconds. When it came back the SQ was lower; 80% on my Humax instead of 90%. (Can't give values in dB since my meter can't handle 8PSK.)
5 minutes later the signal disappeared again, for 5 seconds. The following 20 minutes the signal varied wildly, sometimes the picture broke-up or froze even though strength/quality was at 80/80. Also, the signal was still being switched and off. At one time the signal disappeared, then came back at 70%, dropped to 60%, disppeared, back to 70%, disppeared again and the came back at 80%.
All this time signals on 1N were unchanged.
Haven´t been able to check continously since then, but they've definitely been up to something this morning!
Regards,
Bengt
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Signal here:
11023H - 82%
10847V - 92%
tothbros
Budapest, Hungary
no changes, switchovers, nothing...I have the same exact reception that I had 2 weeks ago.
by now i think that all those little changes we experienced with 1n tp's were accidental, maybe due to some kind of weather conditions...all this anxiety created a whole lot of buzz and unfounded speculation...if we look at the big picture, the satellite was just launched 2 months ago today, so the process is not overly delayed. of course the SES press releases didnt help
Hughes
Humax Foxsat HDR, Samsung Sky+ HD, Skybox, Fransat HD box, Fransat SD box
Several dishes up to 150cm, receiving 28E 26E 19E 13E 9E 5W
Lugo, Galicia, Spain
Still in the realms of speculation I'm afraid, but from what I've gleaned from the many recent contributions, The transponder 11023H is transmitting using parameters which make fringe reception particularly tricky. Other transponders, for example those sending in SD and Vertically polarised could display rather different characteristics. Does this seem reasonable? Any way, I'll just have to be patient and start looking into larger dishes and maybe some sort of signal meter to be able to calculate how large a dish I would need. This of course would free up my existing 150cm PF for other duties!
buckshee
1.9M 90% strength & 90% quality
1.35M 80% strength & 60 - 70% quality - Signal jumps between 60% & 70% so probably 65% average.
Same tuner Humax HDR
Weather sunny with partial cloud, windy - time 11.00 am
A lot of variation during the 24 hr period
Mr Hoover
Various Receivers and Dishes
Portugal
Interesting....There must be a very rapid falloff between Guarda and Lisbon/Algarve,
but that seems to be the style of the footprint.
Are the any reception results from Porto (Oporto)?
Hugh
dvdfilm
1.5m dish
spain
it seems the PE beam still isn't on
Bengt
Hi again
Just to let you know, with regards to my previous posting (post #7):
Quality now back to 90%.
1N transponders still unchanged.
Regards,
Bengt
That's over 400km so nothing very dramatic about that. Here, with 2D we had two zones just over 100km apart and one needed a 1.2m dish and the other a 2.4m.
No.
DVB-S2 8PSK 2/3 = 6.6dB threshold (test signal)
DVB-S QPSK 5/6 = 6.5dB threshold (FTA SD channels, BBC2 England, for example)
DVB-S2 QPSK 8/9 = 6.2dB threshold (ITV HD)
The easy channels are the ones higher than 11200 MHz, mostly subscription or rubbish.
DVB-S QPSK 2/3 = 4.4dB threshold (SD channels, Sky News, for example)
DVB-S2 QPSK 3/4 = 4.0dB threshold (ITV2 HD, for example)
And BTW, before this switch 11023H was a lot stronger than the band D transponders, so if they go down by the same amount bigger dishes will be needed.
Hughes
Thanks Huevos for interesting info, so the fact that Public Service Broadcasters are on low frequencies is probably no accident...
mbsnr
Sky+ HD - FTA 43W to 42E
Ireland
I'd say yes it does. I've 2 boxes. One gets 98% on any Astra 1N DVB-S/DVB-S2 TP - short cable run of 7m. The other is on the end of a long cable run with 2 joins and shares the cable with a DTT signal. The same TP parameters on Astra 1N differ in signal quality to 2F by 25% (Other TPs from 1N DVB-S are 98%). I have had breakup in bad weather on 10847V from 1N on that box. I'm on the West coast of Ireland in the 'UK spot' so if my cabling is making a difference, someone else in the fringe zone can easily have issues with TP 11023H but perhaps not a TP with V or a different SR.
i got signal spot beam 10995v 2db up
