tothbros
- May 18, 2012
- Age
- 49
- 150cm Gibertini, Andrews (CM) feedhorn, LNB: C120 flange Invacom QDF-031, Sky+HD box
- Budapest, Hungary
The easy channels are the ones higher than 11200 MHz, mostly subscription or rubbish.
And BTW, before this switch 11023H was a lot stronger than the band D transponders, so if they go down by the same amount bigger dishes will be needed.
i think this depends on the location. here, in the eastern edge of the beam, where i am, the threshold is lower in the 10.7-10.95 range, anything higher is much harder to receive.
and also, 11023H was the weakest tp here by a mile, even before the move to 2F.
