bargain second hand big dishes for sale
That actually sound like one heck of a bargain.
Yes... plus £79 to hire a van to bring it over. Thankfully, it's less than an hour away from me. Picking it up Friday.
Re arms: I am in the process of making new arms for my reflector, I've been experimenting to find the easiest way (low cost), and I hope to have a protorype in a week or two.
I draw on the benefit of having a fully working and mounted CM180, so I know exactly where in 3D the LNB should be, makes is a lot easier to cut materials to resonable adequate lengths. I hope to share, if not the arms, then at least the recipe for making them.
Yep, a simple design, which would allow the addition of off-centre LNBs would be good too. I am in no particular rush as I won't be installing it until we move (hopefully this year) but I do want it to be perfect and as close to the original as possible.
In the meantime, I can make a start on modifying my polar mount to take the dish. But will open a separate thread on that.
Archived-1
Persona non grata
uk
Great stuff Alex so glad you've got one, now I can bug you to get it installed :D, my offer to make you the arms still stands, just give me a shout:).
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Congrats CJ! Why did you need another dish?! Just kidding. Good catch. I would advice to go for feedarms made of INOX (not so much more expensive, but will look nicer)
Archived-1
Persona non grata
uk
Hi Alex, you should give shiply a try, I was going to buy the 2.4 from Ireland (but decided against it) this was the cheapest quote I received other quotes was around £130.
Yeah I thought about it but I wouldn't trust them to bring the dish in one piece. Probably ok for furniture but not something like this.
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
archive10
Spoke to the seller this evening and these are ex telenor stock, thus maybe for signal relay purpose not satellite reception.
Regards
Well, a metal parabolic dish is a metal parabolic dish.
Should reflect most microwaves.
There's a substantial mount in the background somewhere.
Skomedal: Can you put up something like this, or do you have local regulations (and much worse: Iffy neighbours?)
Should do 28.2 nicely, I would speculate.
skomedal
This and that
thule
No restrictions as far as i can see, as my house is in a forest, local rural community 5 households spread over 3 km and nearest village 41km.
But think that size dish would be overkill:D
Regards
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
1.8m fibreglass dish Eb*y: 251963072589
What's the 1.8m? The seller says it's not motorised but it's clearly sat on top of a polar mount.
1.3m looks like fibreglass - maybe one of Prodelin incarnations?
