So ..that is the SL3 off the menu ..
The filters are too good where the ka stuff is allowed to pass ...and output to the IF line ..the ku is is effectively muted ...
Lider gets through at around 10db ...even though this is a true circular polarised lnb ..
The only hump in the trace is at the lower frequency of 12245L ...
Which simply isn't strong enough ...
This hump isn't present in a V/R scan so must be for real ...but sadly the 'filtered' or 'muted' part of the spectrum is not available to scan ..
I guess Directv dont use it on the SL3 ..so is muted and where ka is injected into the IF ..
damn ..
Actually the DO use this bit of spectrum on
DirecTV 4S at 101.2°W but not on the SL3 ?
maybe it's one of the add on lnbs ...(one of the Eagle Aspens perhaps)
At least that's my curiosity satisfied..
doh!!
Or maybe the SL3s ability to mute this chunk of spectrum can be turned off under command control of their dedicated receivers ?
