36B at 36.0°E
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Getting the below tonight from here, using a standard lnb
12092 H/R Russian beam
11727 V/L Russian beam
12072V SSA beam
can you post some screen grabs buddy ?
Archived-1
Persona non grata
uk
My pleasure :), I made a mistake with 11727 its on the SSA beam not the Russian as stated, still a hard catch though and locked in on STB:).
Well done Martin. I suspect that I'll see zero from the Russian beam here but may have more luck with SSA being further south.
Archived-1
Persona non grata
uk
Its a bit strange here 11727 is just as hard to lock than 12092, I will try the circular lnd again when I get the chance.
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
ive tried the freq 12073v now getting roughly 28% but not locking
nothing from 12092h or 11727v
hi martin is those freqs off the 1.2mor the 1.8m ??
Archived-1
Persona non grata
uk
1.8 Steve, I am still locking them this morning.
parkiepie420
well done martin !!
are you receiving any of the freqs on the 1.2 m ???
Archived-1
Persona non grata
uk
Ive not persevered Steve because I no I wont lock them with my 1.2 but I did get a sniff from 12092 just moved to 3%. 1.8 is the minimum for these at our location for a lock.
parkiepie420
just thought I would ask as ive got a signal at 12073v but cant lock it though !!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks for the pics Martin ..
Excellent job mate ..
I gave up trying on this but am still interested to see what others manage to get..
12092R is a total mystery to me ..and is easily the weakest RHCP transponder at my location ...most of the time not even a hint of 'NO-Locked'
rgds
VS
Archived-1
Persona non grata
uk
rgds
VS
Thanks Evan, why not try chasing some others we have had 31.5 W 17E 42E 7W 30.5E ?, are do you only like L/R lol.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
More like ..
Having paid for a dedicated Circular polarised Ku upper band lnb ..
I just wanted to see it put to practical use ..
lol
Archived-1
Persona non grata
uk
I see pal, ive not managed to track properly to 56E yet it might be ok now I tweaked in a bit better yesterday, once I have it tracking as it should I will be chasing this one :), I am not expecting much though, Edit I am sounding like others :eek:, I will lock it in in due course :D well I will give it a dam good go :).
A while back, I've been speaking to a chap on this forum (Frank/Sergey), living in Denmark. He tested a number of circular LNBs for receiving 36E Russian beam and he found that his home made depolariser plate stuck inside a linear LNB worked better than a store-bought circular one.
The plate has to be thinner than in C - something like an old credit card should do. Something to try...
Archived-1
Persona non grata
uk
I took the cap of the C lnb the other day, it would be easy to swap the plate, is the plate cut to the same size Alex do we know, can you get any pictures pal ?.
nelson_b
Contributor
That was my hope the other night - with the 1.8 alcoa ... post #91
and although it pushed up the db level to 6.0 0n 12129 it wasn,t enough to lcck
a plate made from an old cassette tape box worked better than a credit card one on that setup .....
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I too have had slightly better results with an inverto linear Ku ..with a polythene plate borrowed from a DirecTV Eagle Aspen LNB ..
The plate is thinner but not credit card thin ..and specifically designed for use in the upper ku band.
The results were promising but still insufficient for lock on any of the Russki circular beams.
As said already ..
minimum dish size imo is 1.8 ..
certainly at my location.
rgds
VS
Archived-1
Persona non grata
uk
Thanks Alex I will have a good look at the links, atm i have only tried the C lnb and a 0.2 db technomate here, if it stays nice around t time i will cut a plate and try a few more.
Archived-1
Persona non grata
uk
I've just put the C back on, if i scan 12092 12244 scans in, also using 10750 lnb setting it wont lock it, 9750/10600 is fine and 10600, certainly getting better results with a normal lnb, i will try a plate in a normal one :).
