- Jul 2, 2005
- Location
- Epping Forest
- Epping Forest Essex
To get the most out of your TM5502HD I have compiled a Tutorial on the Blind Scan as some of this information is not in the manual.
These are currently the Best Receiver for Feed Hunting in my opinion TM5502HD / TM5302HD,
For a quick & easy set up to find out what is active on a satellite,
Go to 10 east feeds satellite (Active in the Ku band 10.7 to 11.7GHz & 12.5 to 12.75GHz
For quicker results I usually split the Ku band up into smaller groups with the most active 1st
Method 1
Move to the satellite that you want to search
Now to see what is active between 10700 to 12750 on this satellite use the Satellite Finder (Spectrum Analyses)
Menu >> Installations >> Satellite Finder
Part-1
1/Installation
2/Advanced search
3/Move the cursor to transponder & press ok this will show the list of transponders
4/Press the yellow button Delete All & press OK then exit exit
5/Now go to Blind Search & press OK
6/Select transponder range for the 1st scan
7/Press ok now set From 10950 To 11200 using both vertical & horizontal polarisation (Or what you have observed via the Spectrum Analyses)
8/Select Step Scan @ 6MHz & press the red button to search
This method is a lot faster than going through the data base that may include 40 transponders to delete non active transponders
Part-2
As above 1 to 6 now for the 2nd scan select From 11450 To 11700
Part-3
3rd scan From 12500 To 12750
Part-4
11200 to 11450
Part-5
10700 to 10950 Vertical polarisation
This completes the active part of the Ku band used by Eutelsat 10A @ 10 east your channel list for this satellite
will now be up to date provided your Dish & Lnb have been set up correctly.
Eutelsat 9A @ 9 east uses 11700 to 12500 for DTH broadcasts.
Before you start a scan you can either remove the dead transponders manually one at a time or you can delete all transponders
on a satellite via the Yellow button accessed via Menu>> Installations>>Advanced Search then move the cursor down to Transponders
then press ok & the option will appear on the Yellow Button "Delete All"
Now exit exit & go to Blind Search,
It is only advisable to do this on Feed Satellites not on Direct to Home satellites such as Astra 28.2 east 23.5 east 19.2 east
Hotbird ect.
Some satellites uses all the Ku Band others use only part of the Ku band Spectrum I will upload my latest guide later today.
Method 1
Part-1
1/Installation
2/Advanced search
Part-2
Part-3
Part-4
11200 to 11450
Part-5
Hotbird ect.
