New Lnb changer
Archive4
Oh yes, just remembered the coded message. You stated the elephant was made on this, and since this is your first assembly for a laminas, check the book of Genesis. 38 28 - 30!
Trust
Nijmegen Netherlands
A to b should only be 1125
a to c 1200
and b to c 835
My angles are just a guess!
Made detail pictures , dont not know how You calculate those data from my vertical stand pic .
Frontline dish = 90º Focal line 22º
Archive4
I didn´t calculate them, I measured them!
I stated "
Just checked you pic.
A to b 1300
a to c 1230
c to b 900 "
Then advised my measurements.
It was only in jest, just happened to notice, knowing the approximate measurements, that your original picture was a near perfect 1:100 scale, so using one of these
checked your measurements of the pictured set up. ( Which has changed, for example no clamp in the original pic, now clamp at point B )
All irrelevant to the topic, just my sense of humour. Sorry
Please continue with the very important task and I am here if you need any other checks done. Even if it means you have to make a " best guess " using the average distance measured by two or three people.
Archive4
Why I didn´t think of this before I don´t know.
The following pics show support arm with tape attached to dish end, first in the centre of arm, second to the edge at line of usable dish face.
I´ll let you decide the measurement to where you want it.
Retired human
Hope @Trust1 is busy knocking up the steelwork this weekend!
Trust
Dont be angry , but today by the lack of more data for the Lami , I made a CM changer with the Parabola calculations maybe @WHATAGOAL1 wants it .
R@Rimants an I used that parabola data after we first set up the 1.8 CM with the original feedarms .
At channel 12.637 H at 4.8º E the signal increaced from 9.9 to 10.8 dB .
At channel 11.766 H at 4.8º E the signal increaced from 13.9 to 14.9 dB .
With that data for the AS-1800 , the spot on the vertical bar frontside the dish is at 730 mm from the bottom!!!
Not sure the same will happen wit that Lami , I wish I had such dish here to test .
As you can see , the sidearms must be extended with 200 mm long M6 inox rod .
I decided to use the TechniRotor pole clamp to attach the mainbeam onder the dish .
Its very stable and at that way more easy to lift or lower the beam wenn neccecary .
Archive4
Sorry, previous post should have been 1:10, not 1:100. All beside the point,
I have a spare here, Laminas that is, I´ll post it to you, if you wish, when you´re done, post it back. Please!
Retired human
Something tells me I should have installed the Channel Master :(
Archive4
Any fool can install a Channel Master with rotating lnb, it takes an expert to install a Laminas with rotating lnb!.... Well maybe a few experts and a couple of others who wish to help out!:-ohcrap:-ohcrap:-ohcrap
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I would be happy to help, but only after owners of Laminas 1,8m measure and agree between themselves on 3 measurements:
- width of the WOD (precision 1mm), distance AB;
- height of the WOD (precision 1mm), distance CD;
- depth in point where AB and CD cross each other (precision 0,1mm), distance EH.
Archive4
If you send me two precision 360 laser levels and a digital micrometer, I´ll be happy to oblige! In the mean time you will have to wait for the best guess and bit of string measurements!
RimaNTSS
N-E from Riga
In that case, you all (owners of Laminas 1,8m) wait LNB-changers. I doubt that second can come before first.
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
@Trust1, yes whatagoal1 is waiting for changer, if you pm where to send money and amount, skrill is easier, but can do paypal, whichever you prefer
Archive4
Just as well I´m not waiting, on account I can only afford one lnb. Just trying to help out with old fashioned tape measure and a brain, neither of which will calculate to 0.1 mm, and have doubts that all but a rare few, and maybe NASA can.
RimaNTSS
N-E from Riga
Then do as precise as you can.
Retired human
We are going around in circles here. Both me and Milamber took several measurements and several pictures of our methods. Yes, there are minor differences in figures but it's as precise as we can get. I am not sure what else we can do... we don't have laboratory level measuring equipment...
Archive4
At least, they are ever decreasing circles! Suggest we await the results from the German jury, when advised by Trust1 ( @Trust1 )
RimaNTSS
N-E from Riga
Yes, but straight distance AB is possible to measure with the precision of 1mm without any problems! But I see that @Milamber measured 1936mm and you 1930. And this is very important.
Archive4
Oh come on! Be fair! I had the advantage of a second dish I could lay flat on the ground. Unless your 2.5 meters tall and have four arms and two heads, getting a measurement to within 1 mm is impossible on a mounted dish!
RimaNTSS
N-E from Riga
I can assure you it is perfectly possible and not dependent to how tall are you.
