@Feedsat_DXer how are you finding your rotator?
Maybe there are limits programmed in the motor?I haven't find yet how to make a complete rotation (350°) with a TBS card, it stop at 160°.
do I have to know something to know about this rotator ?
Yes, no problem with the TBS card 5925 now, I found how to fix it:
rotating each position manually , set and store it with EBS for example and no problem, since a couple of weeks, 3 KA (A B C/D, 2 Cband , 1 Xband and 1 KU are installed.
I just notice one little problem, the total net weight of everything is important; and sometimes, the elevation motor has some problems to move the antenna to the up position.
Later this year (maybe during summer holidays) I will installed the CM180 with the LNB chnager by the TBS6983 but I don't think there will be any problem or surprise.
I had in the past a simulair problem , thats why I want to make declination control instead of elevation .
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Yes, no problem with the TBS card 5925 now, I found how to fix it:
It took me a week of fine tuning everything - I nearly gave up. But it's working good with signals on par with the original arms.For me, very difficult to find to have a similar signal with the Lnb Changer with what I get with originals side-arm and the Laminas main arm, everything is still dismantled yet.
