Advice Needed my future plans
I find that odd. Some of the TPs on 9E are as strong as eg 13E.
Finger trouble with the receiver, more likely.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
your right, i am getting signal on 9e now
Blind Scan 11700 to 12500 @ 9 east all TV
Blind Scan 10 east 10950 to 11700 + 12500 to 12750 All TV
Hotbird @ 13 east Blind Scan 10700 to 12750 All TV
All the transponders with a European footprint can be received with a 60cm dish.
FlySat Eutelsat 9B @ 9° East
John Pykett
Persona non grata
update 2: just found out im unable to get 9e
Comment deleted after I read the latest ones from John P & others (been out all day and just followed the emailed link:rolleyes: )
John Pykett
Persona non grata
Reset your motor to DiSEqC 1.3 USALS then you will find it much easier to add new satellites,
Go to 1 west & set your Latitude & Longitude.
Hucknall/Coordinates
53.0342° N, 1.2029° W
So the USALS settings for your location is 01.2 West 53.0 North
John Pykett
Persona non grata
yeah the settings are set at that, it allowed me to get 9e but i dont know how to get other sats apart from the ones i get
The all you need to do now is add the strongest transponder from this list here Just Sharing This - Strongest Transponders
To make active a new satellite position for example add Eutelsat-12West A @ 12.5 west 11390 V 27500 KTO
Installations >>> Satellite set up>>> now move the cursor down the list until your find Eutel 12westA now press the yellow button to save exit & move to advanced search to the 1st transponder 11008 V 2141 if it is not there then press the green button to add it,
Exit again & move to motorised settings now move the cursor to the bottom until to come to Go To then press OK
You will be asked "settings were changed,do you want to save them" Select Yes,
The dish will now move to 12.5 west so exit this menu when the signal bars light up & go to advanced search move to the 1st transponder now move the cursor to Scan & press OK
You can now exit & view your new channel RIT
To continue to populate this satellite you have 3 choices you can try Installations Auto Navigate move the cursor to the right hand menu & press OK then exit & view your new channels,
To Blind Scan this satellite you have 2 bands 11450 to 11700 Horizontal & 12500 to 12550 Horizontal & Vertical
To perform a Blind Scan on this satellite go to Installations >> Blind Scan press OK & move to the new menu on the right move the cursor to the top TP & press OK to open a new window now set 12500 to 12750 move the cursor to the bottom & press OK,
When the scan is complete you can view you new channels,
The 3rd method is to add the data manually from this list FlySat Eutelsat 12 West B @ 12.5° West
John Pykett
Persona non grata
The dish will now move to 12.5 west so exit this menu when the signal bars light up& go to advanced search move to the 1st transponder now move the cursor to Scan & press OK
okay
John Pykett
Persona non grata
quick question, why is there at the races feed fta on 7e?
Welcome to the Elite Club of Feed Hunting.
There are lot's of Free to Air sports feeds on 7 east 10 east & 12.5 west ect they are fta because it is convenient for the Satellite News Gatherer to beam them from their trucks to the feed satellites like this sometimes they encrypt them but if it is a minority sport like golf they don't always bother as only a very small percentage of the population know about Feed Satellites then the broadcaster beams them up to 28.2 east,19.2 east 13 east for Direct To Home via a mini dish sometimes with added encryption.
John Pykett
Persona non grata
There are lot's of Free to Air sports feeds on 7 east 10 east & 12.5 west ect they are fta because it is convenient for the Satellite News Gatherer to beam them from their trucks to the feed satellites like this sometimes they encrypt them but if it is a minority sport like golf they don't always bother as only a very small percentage of the population know about Feed Satellites then the broadcaster beams them up to 28.2 east,19.2 east 13 east for Direct To Home via a mini dish.
its strange like i thought you need a 1m dish at most to get feeds but on my 80cm dish atr comes in loud and clear
One strong Feed doth not a summer make .......
Most Feeds do indeed need bigger dishes, but not always.
John Pykett
Persona non grata
im not sure if it is a feed though cause its an exact copy of at the races on sky but not encrypted
It is a feed check out my post #196
The Racing channel can also be found on this satellite FTA.
