OCTAGON SX88 H.265 HEVC HD
MCelliotG
Thessaloniki, Greece
I didn't see any changes, it always had combo 2388 (7522 is the SR), so naturally if that combination was already embedded in the firmware, the STB found the channels. No PLS mode and code was blindscanned in reality...
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
stephan94
Bavaria
I was surprised how weak your signal was on Yemen as you are much further south than me & presumably using a 120 cm dish,
I just watched the reception of Yemen TV in the North of Bavaria
7 dB, it's much better than Paris.
InBavaria.jpg yemen2.jpg Paris In at Paris the C band LNB really disturb the reception.
stephan94
Bavaria
Hello
after much trial
I managed to get the Multistream Hellasat of 39 ° East
My new toy is on its way....
Laser
May I ask where is the best place in the UK to get one from?
stephan94
Bavaria
stephan94
Bavaria
I am from Bavaria wit 1,20m Antenne
I don't know if of UK it is going to work. ?
stephan94
stephan94
We'll see what it makes of my 1.8 Channel Master, when it arrives
New toy has arrived. Setup easy. Good points, transponders can be deleted from a satellite in one go ready for a new blind scan.
I find blind scan fairly quick, certainly found quite a few Sky feeds on 16E no problem. Multistream on 39E no problem here in the UK on the CM1.8.
Bad points. The user LNB setting works to a point, it will let you enter say 17.350 for my Hughes,, blind scans OK with the user settings, saves the channels, but then you get a 'No Signal' on the found channels, and the saved transponders are only save as 4 digits!! so a bug methinks! When you add a new satellite the Diseqc 1.2 motor setting will not work, i.e you cannot move the dish! another bug perhaps??
Nice receiver for the price, channel change is very quick! lets hope they sort the bugs out fairly quickly. See picture of 39E multistream, this scanned in easily on a blind scan.P1010055.JPG
..... waiting for the price to drop to around €50 .......
Laser
Will you give 5West a scan re Mulitstream and see how that goes..?
You took the words right out of my soft keyboard :D
No problem, the French and RAI channels scanned in OKP1010056.JPG P1010057.JPG P1010058.JPG
Laser
Looks good. Mines on order! Hopefully won't take too long.
Took mine 2 days from Germany, better than our post!
Thank you for that,
The 39 east Multi-stream has the same code as 45.1 east so will also clear.
NURTS Bulgaria Multistream-3
12717 H 9416 3/4
DVB-S2/8PSK
MPEG-4
PLS: Root/218997
Non of my regular satellite suppliers have this in stock so I will have to widen my search.
Due from Germany next week :rolleyes:
