OCTAGON SX88 H.265 HEVC HD
I will try it again after the Proms & MoTday they all have English soundtracks now :)
Check the software version, a new version was released on Aug 31st..
Excellent picture in HD & SD with the SX88 :)
SimonE
Gloucestershire, UK
When scanning a satellite, do you have to scan the lot or can you put in frequency limits? eg 10950-11200 and can you choose H&V/H /V?
Benoit
Vizyon 10000 HD
Multi LNB dish (Astra 1, Astra 2, Hotbird, Eutelsat 5WA)
France
Using AV Amp now. No difference
The AV amplifier has to support Dolby Digital + (e-AC3) in order to decode the raw audio stream from the french channels others than France 3.
I assume that the audio DSP of the Octagon sx88 can support DD+ if it gets an appropriate SW update.
You have to scan the lot but it is quite fast 10700 to 12750 on 9 & 10 east took 7 minutes.
Sorted now after a Blind Scan the ATV Telecom Bouquet was added to my data base :)
4wd
Getting the picture
5 W, 9-13-19-28 E
Interesting box indeed, quite amazing what they make these days (it's the chipmakers who rules the world :O)
About sound on the French 5w streams, working, impossible, hope ?
Both me and Laser had the same message off Octagon...'we are working on it'
So hopefully...
So hopefully...
Good, thanks for that. I shall hold off purchase until it's sorted.
Even my ancient Humax Foxsat copes with D+, so it seems a bit regressive that some new boxes don't natively support it.
4wd
Getting the picture
5 W, 9-13-19-28 E
So does my Vantage HD 8000, produced in 2007
5wa-jpg.92127
At last a Linux Satellite Receiver that I can use for Feed Hunting :)
The SX88 is very easy to navigate you do need to Blind Scan in the Multi-Streams,
Just goes to illustrate how over complicated some Linux receivers menu's are no other Linux I have tried is as easy to navigate as the Octagon SX88 :D
Man City U23 v Liverpool U23 KO 1pm
Well the Octagon knows it is a DD+ audio track, just no sound. I need to try the co-ax output at the back and connect it to my Yamaha AV amp which I know decodes DD+P1010065.JPG
Well the Octagon knows it is a DD+ audio track, just no sound. I need to try the co-ax output at the back and connect it to my Yamaha AV amp which I know decodes DD+View attachment 110232
I may give that a try through my Yamaha Amp as well soon as I have finished updating the data base on 13 east o_O
Might be easier for you to try than me, my amp is nowhere near my Octagon.:eek:
Sad to say no sound through coax-1 for DD+ other sounds OK through coax-1 so I will explore this later.
Hopefully Octagon will sort this, if the chip will do it that is..
Jerome
90cm dish on Astra 28 and Astra 19, 2 LNBs. Canal+ Cube and HD-Line HD-50 receiver.
France-78
Sure.
Octagon has to improve their test requirement. Coverage is not good enough for such a product sold in whole Europe.
Anyone got timeshift working? If yes how?
