Just Sharing This Channel Master 1.2M Installation/Restoration
CROSSBONES
S.Wales
Why bother putting the Andrews logo on it!
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Agreed. Unless you can somehow mould it to the dish surface, water usually gets behind any self adhesive material and it eventually falls off anyway.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I was going to cut exact shape with a vinyl cutting machine, it seems to last on other stuff outside.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Why not design a rusty spoons logo instead:Y
Going to change my name to RustyNuts I think with all these parts im messing with.
Funny thing is, on USA based forums people think Rusty is my actual name :-rofl2
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Do they also think you are a spoon?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Instead of sticker it is possible to aerograph image to the dish. Good paint will stay forever. I have 1.8m dish painted that way. 180aero.jpg
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
RimaNTSS
N-E from Riga
did you do that?
I did only planning, transportation to professional painter and installation. Now I have this dish hanging on the sealing in the garage as a piece of art.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Raining today so can't do much, but got some "Inox" bolts and washers for LNB holder.
Also had wire brush attachment on the drill to prep some parts ready to Zinc coat then Paint:
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Decided to strip down the CM Polar Mount, will clean these up, remove any rust, primer them and paint them.
I've settled on Original CM Light Grey, also known as Aldi Silver Non Metalic.
All the bolts are going to be replaced with "Inox", Inspected the bearings and they need replacement so will order some new ones.
Most of the scale is still on there :)
RimaNTSS
N-E from Riga
You better not change this bolt. Firs of all scale will be lost, and secondly there is imperial thread..... not easy to find such a bolt in INOX (if possible at all). Existing one looks good enough.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
No this bolt will not be going :)
I will clean up the nuts and zinc coat them. I probably have lots of imperial nuts here...
RimaNTSS
N-E from Riga
I've made several replicas of such bolts, but no scale and Metric thread. IMG_20150930_174735 (Medium).jpg
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
once you've painted the dish apply the logo and then put a coat of clear lacquer over the top to seal it on.
