Ka-Band Satellites
@John Re: 21.3E Hylas 4
This beacon, on 20200.5MHz now appears to be vertical polarisation and a bit stronger at about 25dB S/N. I wonder if I made a mistake, think in it was circular, when I first found it.
There is also a carrier on 19700.0V at a similar strength to the beacon. I can't check above 20.7 at the moment.
Here's the beacon Graham. My Hughes lump has been modified with a DRO screw and needs adjusting for correct LOF, so it isn't showing true ATM.
To do tomorrow.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I wonder if anyone got the feed today of Mike Coupe CE of Sainsbury singing as shown on News at Ten tonight, hilarious
Nope, missed that one. My 18GHz Newsnet lnb was off duty all yesterday whilst the Ka band D was being used to monitor some unknown activity at around 21 East.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I see oddly even ITV news uploaded it :-
Wish there was a cheap way of getting ka band but I guess my spare 1m dish wouldn't get much ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
s-band
Essex
Extra help required here,
A beacon looking signal that seems to be at 21 deg East, does not seem to be external interference, seems to be on a sat downlink and slowly fluctuates from below noise floor up to good levels and very slowly drops back to noise floor. Analyser grab shown at about max level received here in central UK-1.25 Gibby- Band D Gilat rx board. Freq: 21.525, Pol H on rx lnb but unknown.
Observed brief activity again this morning at approx 9.25am UK ... this time on 21.775 and appears to be circular.
... another spike for beacon/Comms chasers - - 4.8East 22000.73 Vertical.
s-band
Essex
Well spotted. I'm not sure of my calibration but it may be closer to 22.000GHz
20Hz bin size
To do tomorrow.
Slightly off topic, do you know just how far the LO can be adjusted either way on the LNB before stability is affected.
Do you have any images of the dismantled LNB ?
About 400MHz higher when the screw is turned in starting from outside the DRO can CH. Unscrewing doesn't lower the frequency by much if I remember. I shall have to check the exact range when its up on the dish next.
Increasing the Hughes LNB oscillator range
About 400MHz higher when the screw is turned in starting from outside the DRO can CH. Unscrewing doesn't lower the frequency by as much if I remember. I shall have to check the exact range when its up on the dish next.
The two units i did went from 19.700 to 20.900.
They both gave a flat response up to 20.520 and then started to drop off but usable to 20.900
Ah, OK John. Unreliable memory. I'll check mine anyway.
Astra @ 19.2 E getting busy, wedding day activity should see a few more .
So is 16E in Ku....
... anybody ideas where this is coming from : .... 21.570 Hor, on or very close to 26 East & possibly inclined sat.
