Es’hail 2 25.5e
Hi everybody ! This is quite new and interesting for me, I am using octagon sf4008 uhd and DRO EK-Ekselans LNB Quad, is it possible to catch this frequency on the system I mentioned above - first of all, how I have to make the necessary adjustments in the receiver and therefore - is this LNB able to catch such a frequency ? Thanks !
I don't personally know your LNB or receiver. If the LNB is a PLL type, then you could try it with your receiver for the 10495 TP.
If the tried frequency is out of range , you will need some kind of converter to shift the frequency to within the IF range of your receiver.
aceb
Prof Tuner 7301 /
Sussex
Got there in the end! Neither of my cards would tune low enough but I found a very old frequency shifter in a box of bits. Tried a Global ADX+ but that only shifted incoming signals 500MHz or 1GHz the wrong way but the other one (unbranded because there's no outer casing) works perfectly so it's now connected via a diseqc switch to a twin Inverto BU, means I can watch it via Dream as well as CS/VLC.
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
TBS 5590
No chance, no CS support. There`s no chance to find out the scanning range. No scanning program supports it, yet.
This card deserves support as it can show so much!
TBS 5925
Start scanning frequency is from 10550.
TBS 6983
OK
TBS 6903
OK
TBS 6903x
OK, but there`s no CS support and because of that a false frequency appears.
BUT LOCKED after manually given all necessary parameters.
TBS 5927
OK
TBS 5520SE
OK, but it doesn`t show all necessary parameters. Lack of support - no blind scan support yet.
Prof 7301
No chance.
Continue what @satosk started with dvbs cards that can scan and lock 11494 H,of course after I configure lnb in StreamReader:
tbs6522,tbs6590 and Omicom S2:
10808 V-test carrier
fereshte
Bulgaria
2,30m prime focus dish with 3 LNBs - C ( Linear plus Circular ) and KU ( Linear ) ; 2,05m prime focus dish - KU circular and in future hopefully - ka band - 103E - 50W ; Octagon SF4008 UHD ; Edision Primo IP ; Inverto Flange white series ; Invacom quad; 36" motors; Especta and Moteck satellite positioners.
Bulgaria
Regarding to the new 10495 frequency I found out that must be 9750 to tune it, because now my Octagon SF4008 UHD does not accept that frequency under 10700. I will with 9750 tuning on receiver then we will see my LNB will get it or not, I have also Inverto White tech flange LNB.
10492 H,2000,2/3,dvb-S2-new symbol rate and fec.
Up ~3.0dB on first TP. For HAM activity?
Edit: I've lost 10946H now, must be just a change of frequency.
10496 H,1000,3/4,8PSK-ON4BHM(found by @Marval)
... Frequencies and parameters are changing quickly now - difficult to keep track of things.
View attachment 122884View attachment 122888
Alice through the looking glass time, John. With the SUP2400, the spectrum output is reversed, so you need to change the LOF for that frequency. Try 8834 or thereabouts for 10492.
Alice through the looking glass time, John. The SUP2400 reverses the spectrum output, so you need to change the LOF for that frequency. Try 8834 or thereabouts for 10492.
Yep, forgot about that Llew :Y
It's a pain. Maybe we could use the C-Band setup on the Promax, which reverses the spectrum (if the LO can be changed from the default C-Band LOF's - not near my Promax ATM).
Ahh right, i'll set mine up for that and give it a go
Well that works using the C-Band option John. You just scan from right to left, the frequencies increasing accordingly. Set the LOF to 12150 :D
(LNB's LOF 9750 + SUP 2400 = 12150)
Good idea you had there Llew, i made a note in my notepad for reference after you suggested it. I'm a knats out with my LO :):Y.
Brilliant John.
Simple maths for that : LNB LOF 9750 + SUP 2400 = 12150 :)
Brilliant John.
... I did it the cheapskate thicko's way Llew - lined the marker up on the main freq and then adjusted the LO readout on the Promax untill it read the DL freq out top left of Promax screen. I'll adjust it correctly now lol.
That's how I found it John, before my brain ground out the maths :-rofl2
.. Spotted and locked at 10495 H. - - - ON4 BHM
HamSat - 0N4BHM  spotted .... . reduced image...jpgHamSat - 0N4BHM  spotted.....  reduced image..jpg
aceb
Prof Tuner 7301 /
Sussex
I left EBS scanning today and found three signals, 10491 is the Amsat loop. It would be a lot more convenient (for me) if CS would loop the blindscan but Crazycat wouldn't add the option.
1=10491,H,2000,23,NBC_QPSK
2=10494,H,2000,12,NBC_QPSK
2=10495,H,1002,23,NBC_QPSK
