Archive4
Praise be to the great gods of Norse,Just arrived home , was all day at/on the river
You were at or on the river/ rather than under it! If that were the case, we would all be lost!
How does that bit fit in this bit!
Has anyone heard from Laminas?
Had a message from Chris re a new order. He advised on the bottomHello,
No news from Laminas until now !
Rgds
Cardiff
Yes indeed, great response from Laminas, we thank you. Also to Cardiff, thanks. Chris, if you are following the link, please thank the designer, design team.Now, if you asked Channel Master (or whatever they are these days) the same question - I doubt we would get any sort of reply like that.
Credit to Laminas! And thanks to Milamber and Cardiff for getting in touch with them.
This even bring more questions , they just took the drawing made by the parabola calculation and wright down : point G is 141 mm higher .Hello,
Here is the reply, from Chris of Laminas:
"Hi
I think this dimentions you may need. Especially important is that focus there is 10 mm before front of lnb arm."
GH = 42 mm
AG = 1025 mm
Focal length = 1100
I think, he put original central side arm on the drawing. (in black)
Thank you Chris from everyone for excellent and fast answer.
Rgds
Cardiff
It aint that simple , three diff, lenght of beam , three diff. angle motor side plates , three diff. side arm brackets .With three different measurements, make three different fixing points...
Makes for two changers 54That´s only 27 variations, no big deal![]()
