- Jul 2, 2005
- Location
- Epping Forest
- Epping Forest Essex
Try loading the patch again then factory reset & switch the receiver off at the mains for 2 minutes then proceed as before save the channel list in the data base on the receiver before you start loading the patch again then you wont have to reset your other settings,
Follow this menu route:-
Main Menu
System Setting
Factory Reset
Save as Default Channels
Load latest Patch >> Factory reset>>Mains off for 2 min>>Power back on Restore Default channels in the Factory reset menu,
Now give it another try.
Main Menu
System Setting
Factory Reset
