- Sep 11, 2008
- 57E to 58W, C-band and Ku, DVB-S2, 4:2:2 and blindscan.
- 38.5ºN, 0.5ºW
What?E2 TLA 4 what?
What?E2 TLA 4 what?
Not really! E2 is the firmware used by Broadcom/MIPS powered Linux receivers. Vu+, Dreambox, etc. It used to be called Enigma 2 but change to just E2 after a court case where a manufacturer claimed rights to the term.E2 TLA 4 what? = E2 (is) two letter abbreviation for what?
... don't you like abbreviations?
Heh - surely for the term "enigma" there is prior art, and those who originally used it in a technical field aren't really in a position to sueNot really! E2 is the firmware used by Broadcom/MIPS powered Linux receivers. Vu+, Dreambox, etc. It used to be called Enigma 2 but change to just E2 after a court case where a manufacturer claimed rights to the term.
Last version of script is here http://files.inbox.lv/ticket/1f1c8fdee7356b28cef08e33538018fb7d9b6989/zap_to_every_transponder.rarWhere can I please download the latest script version from?
Does it scan one selected satellite or a rtange of satellites? Is it possible to limit the scan to 2-3 satellites or to a certain frequency range?
I personally would be interested in seeing this script as plugin. Do you have any idea how to make it? I could give you contact of script maker.Anyone interested in seeing this as a proper E2 plugin written in python that outputs an xml file?
Rima, I like the idea of an automated collection of records, but if I did it I'd just write the code from scratch. Basically, the plugin would have the option to select the tuner and the satellite, and maybe some output options. Then press OK and it would do the scan and write the result to an XML file.I personally would be interested in seeing this script as plugin. Do you have any idea how to make it? I could give you contact of script maker.
No idea. The case was brought in Germany, and failed even though the term is trademarked in the context of information technology.Heh - surely for the term "enigma" there is prior art, and those who originally used it in a technical field aren't really in a position to sue
Maybe I did something wrong but I ran your script like that:Last version of script is here http://files.inbox.lv/ticket/1f1c8fdee7356b28cef08e33538018fb7d9b6989/zap_to_every_transponder.rar
No need to change anything in the file now, just give command like this:
/usr/script/zap_to_every_transponder.sh 48 192 3592
and then receiver will scan 4,8*E-19,2*E-0,8*W
root@et9x00:~# /usr/bin/zap_to_every_transponder.sh 130
satPosE2: 48 satPosInst: 0
satPosE2: 70 satPosInst: 0
satPosE2: 90 satPosInst: 0
satPosE2: 100 satPosInst: 0
satPosE2: 130 satPosInst: 0
satPosE2: 160 satPosInst: 0
satPosE2: 192 satPosInst: 0
satPosE2: 215 satPosInst: 0
satPosE2: 216 satPosInst: 0
satPosE2: 235 satPosInst: 0
satPosE2: 260 satPosInst: 0
satPosE2: 282 satPosInst: 0
satPosE2: 390 satPosInst: 0
satPosE2: 420 satPosInst: 0
satPosE2: 450 satPosInst: 0
satPosE2: 460 satPosInst: 0
satPosE2: 570 satPosInst: 0
satPosE2: 685 satPosInst: 0
satPosE2: 750 satPosInst: 0
satPosE2: 3300 satPosInst: 0
satPosE2: 3325 satPosInst: 0
satPosE2: 3355 satPosInst: 0
satPosE2: 3380 satPosInst: 0
satPosE2: 3450 satPosInst: 0
satPosE2: 3475 satPosInst: 0
satPosE2: 3530 satPosInst: 0
satPosE2: 3550 satPosInst: 0
satPosE2: 3560 satPosInst: 0
satPosE2: 3592 satPosInst: 0
root@et9x00:~#
<?xml version="1.0" encoding="UTF-8"?>
<e2simplexmlresult>
<e2state>True</e2state>
<e2statetext>Active service is now '1:0:1:1897:D:55:300000:0:0:0:'</e2statetext>
</e2simplexmlresult>
Did you change file's zap_to_every_transponder.sh attributes to 755?Nothing
[http://192.168.1.xxx/web/getAllServices] only gives "Page not found!"
Webcontrol of the box works without a hitch.
I frequently use streaming of programs to different computers all over the house.
"Device Info" in Webcontrol gives this result:
Device Name: dm500hd
Enigma2 Version: 2013-10-01-tarball
Image Version: Newnigma2 v4.0.5 2013-10-06
Frontprocessor Version: VNone
Webinterface Version: 1.7.5
Just in case - now I drown in channel information!
I will try a testrun with the logger some day when I'm occupied whith other things
than watching the telly.
Edit -my keyborad dose not unredstand mee!
course/por supuesto.Did you change file's zap_to_every_transponder.sh attributes to 755?
