OCTAGON SX88 H.265 HEVC HD
French tv with audio too?
I can't get DD+
and you?
Regards
I have a clone.
Correct, no audio on the TV. I need to pipe it to my AV amp and see..
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
If YOU succeed, tell me how....
thanks
:-respekt
Laser
Is this all French TV that has no audio or just some?
Pierangelo
Italy
only France 3 with audio.
stephan94
Bavaria
Octagon engineers know the problem.
They will try to solve it, if the Chip allows.
Thanks - It's a deal breaker for me.
Laser
Mine arrived today. No audio on French channels except France 3 which is in MPEG-1
Great pictures and sound on all other channels.
Does anyone know... Does the SF4008 have sound in the French Multistream Channels?
No, the same. Must be a problem perhaps
as Stephen says. I was going to
try the raw digital output to my AV amp and see what difference, if any that made.
Laser
Using AV Amp now. No difference
Laser
Wonder if a download will be able to correct the problem at some stage
Sorry Laser, I misread your post, I thought you were talking about the SX88. Don't know if the SF4008 is the same.
stephan94
Bavaria
The SF4008 has no sound problem on multistreams on 5° west
  • 20170907 2026 - France 2 - Journal 20h00A_edit.zip
MCelliotG
Thessaloniki, Greece
There are two possibilities a STB will play a video/sound codec
1. Hardware capability (the chipset supports this codec). If there is not, no miracles can happen.
2. The chipset supports the codec but it has to be activated. Sometimes manufacturers do have the hardware but don't pay the royalties
So what do you think happens with SX88? My bet is on 1.
My SX88 arrived this morning all multi-streams working :) French tv no sound 5 west.
I did try the ATV Telecom Bouquet & Antena 3 Uniprex on 30 west but to no avail.
FTA Hardware Blind Scan 10 east /9 east 10700 to 12750 takes approx 7 minutes :)
I will try it again after the Proms & MoTday they all have English soundtracks now :)
