- Oct 21, 2006
- See signature
- North Somerset
An item is worth as much as people are willing to pay for it
Thats right for the 90 cm Fibo , not for the 120 .On a Fibo (or any other Gregorian dish), it would be more or less at the centre of the feed arm.
Most professional dishes have the feed attached directly to the backplate, not bolted to the reflector, and from memory the Fibo has a casting backplate which extrudes to the base of the reflector with the boom held by an allen bolt, unless my memory is failing.
and I was afraid to ask 175 euro (ex postage)
Yes I will , but maybe for those who want more then 3 lnb holders , I will have to charge a small amount extra .Let us know if you are prepared to do this, and when you can do it. Definite order from me.......
Ok ! C in the middle ?Mine would be a motor under the dish for a Channel Master 1.8, a 3 way LNB holder one for C band and 2 x 40mm holders.
Is that OK ?
Yes, that is just fine..Ok ! C in the middle ?
Lowering the feedarm and make the lnb support arm longer , gives a longer lnb radius , so more space .@Trust1 : How many 40 mm LNB holder with 2 Cband LNB (including their conical feedhorn) it's possible to put on your lnb changer project for Channel Master 1.80m ?
My best configuration could be:
- 2 KU LNBf (one linear, one circular)
- 2 Cband: one Linear & one Circular,
- 1 SMW KA 'CD'and
- 1 KA "B"
- 1 KA "A"
- 1 : 40 mm holder for "test"
possible ? , if not what is the maximum ?
Thanks again for your proposal .
Like John wrote , I have to know and see the dimentions , but maybe I can manage .How much for a gibertini 1.5 version please?
I can get you photos ect, no problems. But no going to have the money for a a few months. So I will have to wait. But it sounds like you will have your hands full for a while :-)Like John wrote , I have to know and see the dimentions , but maybe I can manage .
The price will be the same .
@ Cris , Love to see some pics of your dish ,
@ John , did you open that Dark motor , what type nr ? is the main gear 360º ?
No, didn't open it up or drive it with any diseqc control from a receiver so it might have some E - W software limit set. It is exactly as it came in the box. All i did was connect 18 volts to it and did a manual E - W travel test with the motor buttons, which seems to give about 170 deg. I will try and do a video clip of it doing E / W travel if the site will allow a video file to load. I drilled my adapter plate , see rough preliminary drawing / pic , to take the 170 deg thing into consideration .... if it will go to 180 deg , i'll just pop another set of holes in it.
The White dish in the photo, on the right of the gibertini 1.5, is my 1.25 dish, fixed on 40.5W so I can see past a pesky tree blocking the view for the 1.5.... thanks for that Chris, i was also interested for the fact that i was thinking about getting a 1.5 Gib at some stage to put some Ka stuff on ;)
