- May 29, 2009
- North York Moors
It would be helpful if one specified which post one was making the reference to.Not possible until you've been inducted into the relevant Lodge.
Spread the words , no objections by me !!@Trust1 , @a33 , @RimaNTSS , @Captain Jack, @cardiff , and others that have helped!
OK guys, do you object if I ask Laminas to view this thread and advise us direct?
Pardon, I don't understand your reply, I've been reading this thread for a long time and I got very excited with the brilliance, is that a bad thing? These modifications is not something you see every day and the outcome should be so interesting!Be a little more considerate to fellow members, please, if you would be so kind, old chap!
Sorry, I was being overly polite, just in case a member of the Laminas staff was already viewing.Pardon, I don't understand your reply, I've been reading this thread for a long time and I got very excited with the brilliance, is that a bad thing? These modifications is not something you see every day and the outcome should be so interesting!
I have no objections.I would like your consent
I think this must be always primary rule.I was being overly polite, just in case
OK , just dont´t <<<<<<<PMO;)I have no objections.
However, totally disagree that person should be polite only in some cases.
All the main parts are ready , waiting for the response from the Laminas employe to stick them together in the proper way .@Trust1 - any progress?
You could post some pics, so we can all have a guess, and then Trust 1 can put us all right!have attached bottom arm to the dish and moter to the bottom arm
cannot fathom out how to assemble side arms, and i seem to have an extra piece of which i have no clue as to what it is
Should look something like thishave attached bottom arm to the dish and moter to the bottom arm
No 5 is alive!Should look something like thisView attachment 93310
Dont be angry , but today by the lack of more data for the Lami , I made a CM changer with the Parabola calculations maybe @WHATAGOAL1 wants it .
As you can see , the sidearms must be extended with 200 mm long M6 inox rod .
I decided to use the TechniRotor pole clamp to attach the mainbeam onder the dish .
Its very stable and at that way more easy to lift or lower the beam wenn neccecary .
